Results 1 to 6 of 6
    Senior Member Cad Monkey 2's Avatar
    Architecture 2011
    Nov 2010
    100
    Default Importing Hatches - Script error?
    I am trying to import hatches from an old file.
    I know how to actually import them by adding a folder to the Options>Files>Support Files Search Path etc.
    I can get them to show up in the "custom" list, but my problem is that most of the .pat files give me an error message when I try to use them.
    These patterns worked fine in v. 2000 - 2002, but not so mutch in 2011.
    The other thing is that the original .pat file contained many .pat files written back to back, so when AutoCAD wouldn't recognize that file I tried dividing them up individually. It has only worked for one of the .pat files, the others give error messages.
    Any suggestions?
    I would post the .pat files, but I'm not sure if I would be crossing any lines with copyrights.
    Thanks for any help.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    What is the exact error message you are getting when you try using one of these old hatch patterns?
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    Make sure each file finishes with a blank line.
    Hugh Adamson
    www.hatchkit.com.au
    Architecture 2011
    Nov 2010
    100
    It says:
    "Error in Pattern File"
    If I continue anyway it says "Error in Reading Pattern File"
    One of them tells me that there is an error on line 39, but I don't see anything especially different about line 39.
    I did notice that the working patterns ended with a blank line, so I went back and hit "enter" at the end of the last line to start another line. I think it got one of them to work, but the rest still don't work.
  5. #5
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    You may have a file
    • containing a pattern whose name does not match the filename
    • containing more than one pattern
    • damaged by wordwrap or inappropriate text editor
    You may have a pattern containing a line
    • over 80 characters long
    • with an illegal character
    • that does not end with a cr/lf pair
    If it's not one of the above, post an example.
    Hugh Adamson
    www.hatchkit.com.au
  6. #6
    Architecture 2011
    Nov 2010
    100
    It looks like it was the name not matching the file name as you suggested.
    Thanks, that fixed it.
  1. Hatches
    By insight design in forum AutoCAD General
    Last Post: 10th Jun 2010, 01:30 am
  2. hatches
    By moduloid in forum AutoCAD Beginners' Area
    Last Post: 4th Jun 2010, 02:02 pm
  3. See through hatches
    By Drock in forum AutoCAD General
    Last Post: 10th Feb 2010, 05:07 pm
  4. Hatches
    By DODGE in forum AutoCAD General
    Last Post: 5th Feb 2010, 10:27 pm
  5. hatches
    By bjenk8100 in forum AutoCAD General
    Last Post: 22nd Jan 2010, 09:41 pm
