annotation & scales not right
barth11496
i understand annotation and scales and how they work but how can you do this....hard set say about 4 scales or whatever you want to a annotation dim so that every time i create a annotation dim it has a number of scales automatically associated with it....it seams that every time i use a annotation dim i have to create what scales i would like to see represented in the viewport if i want to scale that viewport a few different ways for just that one dim....seams like as a drafter iam still going backwards in scaling text and dims in drawings
thanks for your response... but that did not work reverts back to every single dim or text with just the current scale that i have set in model space that i have set...... could you be a bit more specific
thanks again
Sound like you have something clearing your scale list. Maybe you could explain your problem a little better. Do you run any add-ons or LISP routines? Is it just the Dimensions?
