Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 54
    Full Member
    AutoCAD 2011
    Jan 2011
    31
    Default Title block text
    Attached is the start of a title block, which I hacked up from a title block I found on this forum.
    If you use ddedit to change the text you can only ever type one line of text, the return key does not move you to the next line.
    How do I change this so I can type in columns.
    Thanks for any help.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    Make them attributes.
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Go to Draw, block, make. Enter a name for the block, then hit select objects, and pick all the stuff in your title block. Once you save it, you can double click any of the text in your titleblock and it will bring up the enhanced attribute editor so you can edit any or all of the text at one pass
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    You can also build in some attribute enhancements when populating your title block attributes with fields, which get their value from Sheet Set Manager (SSM) properties.
    Client name changed, or submittal date, etc... make one change in SSM, and re-plot. Done!
    This implies a bit of planning on your part, but well worth the effort when dealing with large plan sets (I work with 200 to +500 sheet plan sets).
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    The text is already attributes you just need to save that drawing as Titleblock (any name will do), then you close that drawing and open a new or existing drawing, now insert Titleblock in that drawing and the attributes will work as expected.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Quote Originally Posted by rkent View Post
    Basically the same thing I suggested. The text blocks are already attributes so the only step missing was to combine them into a block. There are numerous ways to do that, now he has 2 to pick from.
  7. #7
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by Jack_O'neill View Post
    Why create a block in the drawing, and then save the drawing, just save it, one step and done? Many beginners end up using the same name for the block and the drawing name making the file unusable.
    I just noticed the OP has the objects in PS, they will have to move everything to ModelSpace, then save the drawing.
  8. #8
    Senior Member
    AutoCAD 2015
    Sep 2010
    New Zealand
    217
    Once it is an Attribute Titleblock you will have the benefit of being able to change lots of drawings very quickly if you ever get into lisp.
  9. #9
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Yes, if you name the block and the drawing the same, that's true.
    Why would you want to save a titleblock in modelspace?
  10. #10
    Senior Member
    AutoCAD 2015
    Sep 2010
    New Zealand
    217
    Then it will work in both Model Space and Paper Space. Your choice
  1. Title Block Logo - Text into lines
    By jalbes in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Mar 2010, 09:46 pm
  2. Can't see text in title block
    By evilCartman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2009, 03:13 pm
  3. Text in Title Block
    By ankurpraja in forum Autodesk Inventor
    Last Post: 3rd Jun 2008, 06:33 pm
  4. How to use bitmap for title block text
    By hyposmurf in forum AutoCAD General
    Last Post: 25th Jan 2004, 02:10 am
  5. Changing Text in a title block
    By Camsec in forum AutoCAD General
    Last Post: 20th Nov 2003, 11:21 pm
