Results 1 to 7 of 7
    Junior Member
    Civil 3D 2010
    Dec 2004
    Michigan
    14
    Default Change File Properties
    Anyone know how to change the Author and Company name that shows up on the General tab in the File Properties dialog box?
    It looks like the Author field is tied to my windows username. I'd like it to be my full name.
    The company name shows a company that we once used to be called. We have since merged with another company and the name has changed. I'm guessing this field is tied to the license somehow?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    What OS are you running?
    Full Member envisioncad's Avatar
    envisioncad's Computer Details
    Windows XP Pro and above
    Dell Laptop Precision
    Civil 3D 2013
    Jul 2010
    Madison, WI, United States
    54
    Hi Dugg, you can create a mvba to run on the files.
    Something like:
    Sub PropertiesDGN()
    ActiveDesignFile.Author = "Bob Mecham"
    ActiveDesignFile.Company = "EnvisionCAD"
    ActiveDesignFile.Client = "WisDOT"
    MsgBox ActiveDesignFile.Author
    End Sub
    OR clear any other properties using this code
    Sub clearProperties()
    ActiveDesignFile.Comments = ""
    ActiveDesignFile.Keywords = ""
    ActiveDesignFile.Manager = ""
    ActiveDesignFile.Subject = ""
    ActiveDesignFile.Title = ""
    End Sub
    Once you have the MVBA then you can batch process all the files at once.
    HTH,
    Bob Mecham
    Junior Member
    Civil 3D 2010
    Dec 2004
    Michigan
    14
    I am using the Microsoft Vista operating system. I did change my user account name btw and that didn't change anything if that is where you are headed with your question?
  5. #5
    Junior Member
    Civil 3D 2010
    Dec 2004
    Michigan
    14
    Quote Originally Posted by envisioncad View Post
    Something like:
    Sub PropertiesDGN()
    End Sub
    End Sub
    HTH,
    Bob Mecham
    Thanks Bob. I will use this if I ever need to change existing files. I'm more concerned with the files I create from here on out.
    Can I put this section...
    Code:
    in a configuration file somewhere?
  6. #6
    Civil 3D 2013
    Jul 2010
    54
    dugg, you are correct the company name is coming from the license server and the username is coming from your pc. There are no variables to help you populate the properties when you create a new file. The only thing I can suggest at this point is batch process the files when you are done.
    Sorry,
    Bob Mecham
  7. #7
    Junior Member
    Civil 3D 2010
    Dec 2004
    Michigan
    14
    Thanks for your help on this Bob.
  1. Change 3d solid properties
    By andremr in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Jun 2010, 11:02 pm
  2. Change Acad.DWT Properties
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Oct 2008, 06:36 am
  3. How do I change the properties of an Xref
    By Calador in forum AutoCAD General
    Last Post: 9th Jan 2008, 03:42 pm
  4. Change Properties in 2006
    By hydro in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2007, 07:29 pm
  5. Can't change properties of a polygon!?!
    By RedDirt in forum AutoCAD Drawing Management & Output
    Last Post: 1st Oct 2006, 09:08 pm
