Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Mar 2011
    1
    Default templates, xrefs, and paths...
    i have searched and searched and i am just not finding the answer to this problem so please link me if this has already been discussed.
    i am trying to set up templates at a new job and i want to create templates with an xref for the title block so when we start a new drawing, we use the template, save to the project file and everything is there with our title block already xref'd. my problem is, the path on the xref'd title block stays the same and is still referencing the location of the file i used when creating the template. if possible, when i save the new drawing to the project foldeer i want the xref to also move to the project file and the path to the xref to change.
    does that make sense? is that even possible?
    thank you!
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Try reading AutoCAD Help on "Set Paths for Temporary Xref File Copies" and "Set Paths to Referenced Drawings". If you have specific questions, comeback here and ask them.
    P.S.
    Look at "Similar Threads" at bottom of this page.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    977
    If I understand your situation correctly, you want to bring a standard title block into each new drawing and make it part of the project. One way to do that is to bind the xref to the drawing. Typically, there is information in the title block that changes from one project to the next, which you can handle with attributes in the xref. If you bind it as a block in the new drawing, the attributes will be ready to use.
    breaking AutoCAD on a regular basis since 1991
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Quote Originally Posted by atothec View Post
    thank you!
    It seems simple enough to copy your template to the project folder and then xref it in. If using SSM you can specify there to use the file in any folder you want, so copy the template over and edit the properties in the SSM for that project.
    You will not find a OOTB setting that will let you xref from one folder and hit save and have it copy to another folder.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  5. #5
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,238
    Have you looked into relative pathing?
    Rob
  1. Replies: 1
    Last Post: 5th Nov 2010, 02:50 am
  2. gray scale xrefs vs. xrefs with full range of pen colours
    By corinne in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2008, 09:56 am
  3. File Paths For Xrefs
    By Primal Scientist in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2008, 11:06 am
  4. Tool paths
    By allmostawake in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2008, 03:09 am
  5. Xref Paths
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 14th Aug 2007, 07:10 pm
