Results 1 to 7 of 7
Thread: limited offset
    Senior Member
    AutoCAD 2008
    Feb 2010
    106
    Default limited offset
    how do i change the setting where I currently have a limited offset when i try to use the push/pull tool?
    it is limited to 65mm!!!
    thank you to someone with the answer
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Thats a new one on me! I'm not aware of there being a limit or a setting to enable one. Any chance you can post your drawing and i'll take a look.
    Word up
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    Senior Member
    AutoCAD 2008
    Feb 2010
    106
    no worries bullseye,
    thanks for getting back in touch on it,
    but it seemed to resolve itself after a while of struggling,
    thanks again
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,664
    Are you sure it wasn't just snapping to something 65mm in height nearby when you were trying to offset the object?
  5. #5
    Senior Member
    AutoCAD 2008
    Feb 2010
    106
    that may have been the case dink, all is well now, thanks very much
  6. #6
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    765
    i think this is where you push/pull and it says "offset limited to ..." which is in your case 65mm.
    this happens when the geometry constrains the face at some point so that to continue the push/pull further would require a node or edge to be deleted or moved. as skp doesn't know what you would do with this node or edge, it just stops the push/pull there.
  7. #7
    Senior Member
    AutoCAD 2008
    Feb 2010
    106
    Quote Originally Posted by designerstuart View Post
    that is exactly what it said and what happened, thanks for that designerstuart
  1. Running Map3D/OptiNT under a limited account
    By Tortuga12 in forum Map 3D
    Last Post: 26th Aug 2008, 05:26 pm
  2. Limited Precision
    By derf in forum SketchUp
    Last Post: 7th Feb 2008, 10:00 pm
  3. limited to 3 viewports
    By BMW in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2007, 02:48 pm
  4. Model space drawing area limited ??
    By g-dub in forum AutoCAD Beginners' Area
    Last Post: 13th Jul 2005, 03:38 am
  5. Free AutoCAD tutorials available on web for a limited time !
    By PacificOcean in forum Tutorials & Tips'n'Tricks
    Last Post: 2nd Jun 2005, 08:11 pm
