Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 57
  1. #31
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Look in the top right corner of each post, the number of the post appears there. For instance this is post #31
  2. #32
    Full Member
    AutoCAD 2010
    Feb 2011
    52
    I see it now. let me prosess what said before.
  3. #33
    Full Member
    AutoCAD 2010
    Feb 2011
    52
    ok, so from the horizontal cutting line to to the bottom of the drawing (to the d bubble) that will be the south elevation. from that same cutting to bubble A will be the north elevation with out counting the vertical cutting linr. is that right?
  4. #34
    Full Member
    AutoCAD 2010
    Feb 2011
    52
    since the horizontal cutting line is in the middle. i will be copying a 72' long x 27' high rectangle. man am i even close to what you are traying to tell me car5858?
  5. #35
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Default South Elev
    This is what it should look like. Hopefuly this will eleminate the situation you seem to be in currently.
  6. #36
    Senior Member Raudel Solis's Avatar
    Raudel Solis's Computer Details
    Windows 7
    Hp dv7 4073nr
    Core i7 720 Qm
    6gb Ram 2/6
    1Gb Ati 5650
    500 Gb internal Hd
    500 Gb External Hd
    Built in & 32" External Hd Monitor
    Architectural
    3ds Max 2013
    Nov 2010
    Arlington Texas
    475
    are yall posting the actual completed drawings he is working on?
    this eliminates the ability to learn
  7. #37
    Windows 7
    Hp dv7 4073nr
    Core i7 720 Qm
    6gb Ram 2/6
    1Gb Ati 5650
    500 Gb internal Hd
    500 Gb External Hd
    Architectural
    3ds Max 2013
    Nov 2010
    Arlington Texas
    475
    though what is up with the building structure
    i would expect to see a concrete cylinder under the foundation to which the I beams or 6*6 are supported by
    example
    5'O/s CLAB 5'R Bell? is what the site surveyor would be drawing on the flags
    five foot off set center line A-B
    five foot Radius Bell
    the bell is to have a larger surface area for support at the bottom to prevent movement of the piers
    il post Example drawing file--as soon as i fix my Acad, ... Acad Mechanical is messing around with it Capture2.jpg
  8. #38
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    The screen shots that I have posted were dated 2009, requirements may have changed. Penn Foster had sent me a distorted hand out much like the screen shot as an example. If the student requests assistance from Penn Foster they will send something like the drawing that is in question.
    There is a discription of the footing and piers that the columns are on. We have to wait for the student to get to that section.
    As far as the learning goes we are not doing the drawing for the students, they still have to do them on there own. When trying to explain certian aspects of the drawing instruction, a picture helps the student to understand what is required.
    I also advise the students to visit various construction sites, and look for the details of the building the is under construction. They get a better idea of what they are drawing with this experience.
    Raudel, The peirs are wiewal in the 3 screen shots, just not detailed.
  9. #39
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Quote Originally Posted by Raudel Solis View Post
    Given the level of actual discernable detail the images provide I doubt that the student in this case is going to benefit as much as you think. Images are posted instead of drawing files to prevent the student from downloading them and submitting the work as his own. We're pretty careful that way.
  10. #40
    Full Member
    AutoCAD 2010
    Feb 2011
    52
    Before i created this thread i had no clue what the "skelton" of a building looked like, i was not familliar with structural material. I did not now how to start my drawing.But thanks to all of you guys advice i cen see clearlly now. the images you guys posted helped me start my own drawing.
    I really appreciate the help i get from all of you.
  1. Drafting Problem
    By racosin in forum AutoCAD General
    Last Post: 27th May 2010, 12:47 pm
  2. 3d drafting???
    By dlxowhd in forum AutoCAD General
    Last Post: 12th Oct 2009, 11:36 am
  3. I'm back... Really never left, but I'm back to posting
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 11th Apr 2008, 05:20 pm
  4. Cad Drafting
    By jony69 in forum AutoCAD General
    Last Post: 2nd Oct 2007, 06:24 am
