Results 1 to 3 of 3
Thread: Radial Hatching
    Junior Member
    AutoCAD 2006
    Dec 2010
    15
    Default Radial Hatching
    Ok folks, this is a tough one. Does anybody have any suggestions on an easy way (or LISP routine) to do radial line hatching in AutoCAD 2006. What I mean is the ability to hatch an object, such as a ring (or doughnut) such that the hatching lines are in between the two rings, and are all perpendicular to the circle. Even better would be a generic routine to allow hatch lines to follow arcs (but that would be dreaming too big for now). Perhaps there is some sort of sweep technique that could be exploded into lines? All I need are the lines, actually.
    Any thoughts or suggestions would be much appreciated.
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Are you familiar with Polar Array?
    Junior Member
    AutoCAD 2006
    Dec 2010
    15
    Quote Originally Posted by nestly View Post
    Nestly,
    Thanks a lot for the tip. With some fiddling, it looks like it can do the basics. An arc hatch routine would be the holy grail, but this trick saves me hundreds (maybe thousands) of steps. Much appreciated.
    Cheers
  1. radial text
    By td88 in forum AutoCAD Beginners' Area
    Last Post: 5th Jun 2010, 12:14 am
  2. Radial Dimension help
    By cijorda in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Mar 2009, 05:14 pm
  3. Radial Dim
    By Rhayes in forum AutoCAD General
    Last Post: 16th Jun 2008, 07:30 pm
  4. Radial offset ??????
    By asptamer in forum Tutorials & Tips'n'Tricks
    Last Post: 13th Jun 2007, 04:00 pm
  5. radial dimensioning
    By maack in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2005, 10:18 am
