Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Default Line type not displaying in model or paperspace correctly
    I've tried MSLTSCALE, LTSCALE and PSLTSCALE set to various numbers, but none of them work. any other suggestions?
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    773
    Firstly set the LTSCALE in Model space correctly so you can see the LINE TYPE correctly (or click on your line and change its Linetype SCale in Properties)
    Once this is correct make sure your PSLTSCALE is set to 0 then your linetype will be View in Paperspace through a viewport correctly.
    I hope this helps let me know if you require any further clarification.
    Ta
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    Is this a drawing you have started or one that you inherited?
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    The default values of 1 for LTSCALE, MSLTSCALE, PSLTSCALE, and CELTSCALE should make the line segments display and print the same length regardless of viewport scale. (regen may be required after changing scales or scale factors)
  5. #5
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Quote Originally Posted by JBullseye74 View Post
    Ta
    JBull - Was able to get it on up model (however, i had to put ltscale to .0001). Chaning PSLTSCALE to zero did nothing however.
    SLW210 - I made the drawing myself
    Nestly - that did nothing to my drawing.
  6. #6
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Can you post the drawing, that LT scale is crazy. The line would have to have and individual scale in it's properties roughly the inverse of .0001 for it to display correctly. For example, when LTSCALE = .0001 and an individual property scale of 10,000, will display the same as LTSCALE = 1 and a property scale of 1
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    Have you drawn in Model Space at something other than 1:1?
  8. #8
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Odd, I tried to respond 2 times already but it didn't go through sorry if this is somehow a triple post.
    How would you like me to post the drawing? Host it somewhere?
    Also, SLW210, I've been drawing the whole drawing on 1:1. It's a street and I'm adding traffic lanes and an intersection.
  9. #9
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    If you click "Go Advanced" at the lower right of the Quick Reply window, you can attach the drawing to your post assuming it's not to big.
  10. #10
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Here is the drawing. Also thanks everyone who is trying to help an autocad novice like me! heh
  1. Batting linetype not displaying correctly
    By Vaughn in forum AutoCAD General
    Last Post: 8th Sep 2010, 07:41 pm
  2. Line type not showing correctly in model space
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2009, 03:27 am
  3. CG omega text not displaying correctly
    By Chewi3 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2007, 11:56 am
  4. why my line type does not show on paper space correctly!!!
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2007, 04:46 pm
  5. line type are different in model and viewports
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2007, 04:00 am
