Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    When I open your drawing and check a dimension I see that it is not close to actual size. A 12' width measure 1/32" (or less). Draw to true size so 12' is either 12 units or 144 units (if using inches and not feet). Once I scaled the objects up the linetype worked fine.
    The line had a thickness set to it, which gives a Z thickness. If you want a wider line use the pline command and specify a width.
    Also the line was set to a linetype rather than a layer set with a linetype. Generally it is better to have a layer with the linetype you want and draw on that layer for dashed lines, etc.
    Don't use the "ISO" line types, load the others, dashed, hidden, etc. with out the ISO in the name.
    Finally,
    FOR 2008, 2009, 2010, 2011
    MSLTSCALE = 1
    LTSCALE = 0.5 (this can be adjusted up or down based on personal preference, etc.)
    PSLTSCALE = 1
    Once set you never have to adjust again while going from PS to MS.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  2. #12
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Yeah, the 12 width measurement wasn't to scale. Just to let them know roughly where to paint the new lines. Thanks for all the help though rkent, i'll get working on it.
  3. #13
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Your drawing isn't 1:1 ..... it's 0.03710196 = 12'-0"
    To draw at 1:1 you'll have to scale your .bmp and all your existing objects up with the reference option so your lanes are actually 12 feet wide instead of making your drawing fit the .bmp image and then over-riding the dimensions. You'll also have to change your dimstyles, but that's really the direction you need to go to be proficient in AutoCAD. If you can attach the bmp, I'll try to get things lined up so you can compare how you're doing it now to how it's done at full scale.
  4. #14
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Yeah, I was going to also say when tracing over an image to scale it up to true size. I am guessing this is the area according to google maps.
  5. #15
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Try out the Google Earth add on for AutoCAD from Autodesk Labs. http://labs.autodesk.com/utilities/g...xtension_beta/
    It will come in at 1:1 scale.
  6. #16
    Junior Member
    AutoCAD 2008
    Mar 2011
    12
    Thanks for all the help guys, I got it figured out. When you guys said 1:1, I thought it was the "annotation" 1:1 scale. not 1 feet = 1 feet.
  7. #17
    Senior Member TheCADnoob's Avatar
    See details...
    TheCADnoob's Discipline Details
    Drafter
    See details below.
    Got a degree in rocket surgery that I cant use so I'm doing CAD work. I literally have my hands on all disciplines and am loving every minute of it, unfortunately by not specializing I believe I have found the Zen Noob. Jack of all master of none.
    AutoCAD 2013
    Mar 2015
    246
    I had this problem too. I didn't realize what was wrong until i measured elements in the drawings and saw that they were in scientific notation lol. I drew a line (around the size i wanted to to be) and then scaled it to that reference. Another notch in the noob poll.
  1. Batting linetype not displaying correctly
    By Vaughn in forum AutoCAD General
    Last Post: 8th Sep 2010, 07:41 pm
  2. Line type not showing correctly in model space
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2009, 03:27 am
  3. CG omega text not displaying correctly
    By Chewi3 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2007, 11:56 am
  4. why my line type does not show on paper space correctly!!!
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2007, 04:46 pm
  5. line type are different in model and viewports
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2007, 04:00 am
