Edit the sketch.
There is an example in this tutorial
http://home.pct.edu/~jmather/content...orial%2014.pdf
and this one
http://home.pct.edu/~jmather/content...torial%206.pdf
I drowed a sketch, 1 spline (curved) 3 lines, extruded it, an how I can change the points of spline from sketch with canges for solid form directly?
thanks
Edit the sketch.
and this one
Autodesk Inventor 2013 Certified Professional
http://home.pct.edu/~jmather/content..._Tutorials.htm
the problem was that in Inventor Fusion, I edited the cketch but the solid does not apply transformations, Now with inventor professional it works... Is it true that all what I do in Autocad Architecture i can do with Inventor? always ai attache a jpg i draw lines and polylines on image, extrude them , subtract, union , ant some parameters... where to find ploting settings, plot scale, style - for export to pdf, or jpg 3d hidden,lines... ?
Inventor Fusion very different from Inventor.
In Inventor a part is an ipt file, an assembly is an iam file and a drawing is an idw or dwg file (similar to the real world).
Go through the built in Help>Learning Tools>Tutorials and Skillbuilders.
ok, thanks
