Poly lines
skenderbender17
Hello!
I'm having an issue with my poly lines. they aren't filling in. And its only in one drawings. Even if I do a solid it comes in not tilled in.
I tried doing the fillmode but that didnt work.
I tried the shademode but that didnt work either. I'm not sure what else to try. Any ideas?
Thankk youu,!
Is your polyline 'closed' type list and if it says open then it is not a closed polyline.
See if you can region the polyline
If the polyline is not 'closed'
Try Pedit and go E for edit vertices
where the 'X' is is where the fault should be
  • 1 year later...
That worked for me, too. But I'd like to understand what was happening. What was the hollowness of the lines telling me and what did the UCS and Plan commands do?
