Results 1 to 7 of 7
    Forum Newbie
    Inventor 2010
    Mar 2011
    3
    Default autocad and flow water jet
    hi all great forum i work at a metal fab plant as far as drawing im learning here is my problem i can draw a part save it as a dxf file but when i load it onto flow path instead of a soild cut line it a broken line what am i doing wrong? thanks
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    I am not familiar with flowjetting or CNC although are you drawing a polyline with multiple points possibly in AutoCad and then the flowjet software does not support polylines and is breaking your polyline into multipel line segments?
    Forum Newbie
    Inventor 2010
    Mar 2011
    3
    ive tryed drawing with the line comand and the rectangle i watched a vid on youtube that may be what im doing wrong if you draw a circle in cad and move your cursor to it the whole circle highlights on my drawing each a single line highlights ? this moring im going to draw just a simple stand alone circle and see if flow reads it correctly im just started trying to learn cad im trying to baby step it ( i think i can... i think i can .. lol thanks for your reply dink
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,116
    What software does this Water Jet use? Different devices need different methods. When I used to draw templates for a CNC and Plasma burner, I just had to make sure everything was a "CLOSED" polyline with NO GAPS. By CLOSED I mean actually closed, not just connected, there is a difference. It has been awhile so I do not remember the software that converted.
  5. #5
    Forum Newbie
    Inventor 2010
    Mar 2011
    3
    flow water jet system have thier own software its called flow cut and flow path give me a example please if you could on how to close a line thanks
  6. #6
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,116
    See if this helps.....
  7. #7
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,116
    There website claims easy to use and can import DXF, etc. If you still having problems you should contact http://www.flowwaterjet.com/. Did you not get any instructions with the software?
  1. How to create water effect in Autocad?
    By odod in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2010, 11:42 am
  2. Flow Arrow
    By mgonzales in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2009, 02:34 am
  3. Making water in autocad
    By Bowl.Spliffson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Mar 2009, 01:27 am
  4. Designing of water supply and sewage water pipelines in 3D
    By gicasdd in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Sep 2008, 08:53 am
  5. Changing a cold water pipe into a hot water pipe
    By Siberian in forum Autodesk Software General
    Last Post: 31st Jul 2006, 11:34 am
