Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Plotting points
    Junior Member
    not specified
    Feb 2006
    11
    Default Plotting points
    I have lots of co-ordinates to plot into CAD - is there an easy way to do this without having to type in each of the points individually? Such as using the data from a spreadsheet.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Using vanilla AutoCAD?
    How are the coordinates ordered?
    N,E,Z ???
    Try ASCPOINT.LSP at http://www.caddzone.com/free.htm
    Junior Member
    not specified
    Sep 2005
    Cornwall, UK
    10
    I've was looking for a bit of lisp code for that very purpose also.
    In the end I came up with
    IMPORTXYZ.lsp
    If you look in the lisp forum, there is a link there and another piece of lisp code that also imports points from a .csv file.
    Junior Member
    not specified
    Feb 2006
    11
    Sorry forgot to say, i'm using autocad 2005
  5. #5
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    How do you want them plotted - as individual points? Connected by a polyline? If you get your coordinates in a single column in Excel, in format x,y,z you can copy the whole column of data and paste into AutoCAD when prompted to enter or pick a point.
  6. #6
    Junior Member
    not specified
    Feb 2006
    11
    Thanks that worked!
  7. #7
    Full Member
    AutoCAD 2007
    Apr 2006
    Phoenix, AZ
    92
    Diggin up an old topic because I'm just full of dumb questions today...though, this may not be so dumb...
    I've got a huge list of points from a scene survey that I need inputting into Acad, normally this would be easy, just make an excel spreadsheet with all the X,Y,Z points and run the LISP routine and badda-bing badda-boom... But these points are using a Vector Location (i.e. I have Horizontal Angle, Slope Distance and Vertical Angle data, not an X-dist, Y-dist, Z-dist). Horizontal angle as best I can guess is from the postitive X-axis (around the Z-axis), and vertical angle is from the positive Z-axis (around the X-axis????). The Slope Distance is the distance from the Total Station (origin?) to the point of interest.
    I know this can be done fairly simply with lines, make a line at the desired angle of the disired distance, then make a point at the endpoint of the line, and erase the line...but I've got 250+ points, and well, that would take all weekend, haha.
    I found something in Acad Help that was something along the lines of making a point with a string [dist<angle1<angle2], however, when I tried it, it spat out "Invalid Point." So....is there a command to make a point with "coordinates" in a vector system?
  8. #8
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Sounds like you have survey data that is not "reduced", it has the raw data from the survey. If you aren't able to get the reduced data, you can reduce it yourself (not recommended if it really is land survey data, should be done by the surveyor). *IF* al the points are relative to a single station location it may not be too difficult. I suggest you do the comps in Excel first to create the XYZ data then import as you usually do.
    You're correct, the slope angle is relative to the xy plane. So first get the horizontal distance (projected on x-y plane) using the cosine of the vertical angle. The sine of the angle times the slope distance is the delta z value. Now with the horizontal angles and the horiz distances, calculate the delta x's and delta y's.
  9. #9
    Full Member
    AutoCAD 2007
    Apr 2006
    Phoenix, AZ
    92
    *yawns...* This is gonna be a long night....this has to be done in CAD by Noon on Monday so I probably will not be able to get reduced data from the surveyor.
    Well, it's scene survey data from an accident scene. Points were taken at the edge of the road, skidmarks, impact location, etc etc.
    The complete set of data I have reads something like this:
    Pt#: 1, HzAngle: 165.0224, SlpDist: 463.900, VtAng: 92.5940, ParOff: 0.000, PerpOff: 0.000, TgtHt: 5.000, Description: EP
    That's just point 1. It goes all the way to 272....
    I guess I'd better get back to work then eh?
  10. #10
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Well once you get the formulas figured out, 272 points is not much worse than 2 points
    Be careful on vertical angle, 0 degrees is usually straight up so for angles greater than 90 the delta z will be negative. And be sure all numbers to the right of a decimal are decimal fractions, and are not (for angles) degreeminsecs.
