I'm gonna have to go with negative on that one...but I have been wrong before...once...
Afternoon all.
AutoCAD 2006 - When working in modelspace on multiple details you can sometimes end up with a few details not being used i.e. not on a paperspace tab on a drawing border.
Is there a way of seeing in modelspace which details/drawings are in viewports and which are not so they can be deleted?
AutoCAD 2010
'"Accept that some days you're the pigeon, and some days you're the statue."
AutoCAD 2005
ADT 2005
What I like to do is put rectangles (in model space) on the defpoints layer around whatever will be displayed on the page. Then I use modify my viewport's corners to the rectangles corners.
AutoCAD 2005
ADT 2005
hmm yeah i thought it was a long shot...
Looks like rectangles it is then.. if i remember.
Cheers Dommy2Hommer.
AutoCAD 2010
amendment to my last post..!! oops sorry i got your name wrong.. 'Dommy2hotty'
AutoCAD 2010
It's okay Bender....er...Jimmy...
AutoCAD 2005
ADT 2005
Kewl so this can actually be done by drawings a square over your viewport. Typin in CHSPACE and transphere square into Model Space - cheers CarlB for that one.Originally Posted by JIMMY
AutoCAD 2010
Jimmy, can you tell me what exactly chspace does? I didn't understand your post and I can not find the command in help or in my book. Thank you.
Sure no problem - If you have any text or objects in paperspace which are over your viewport i.e. if you have a detail which you have drawn in model space but you have noted up in Paper space - this comand enables you to select the text / objects in paperspace and transpher them into model space at the same scale that the viewport is set at.Originally Posted by orionengineer
Hope this makes sense.
AutoCAD 2010
Yes, makes sense, thank you. Cool command.
