Results 1 to 4 of 4
    Senior Member alijahed's Avatar
    alijahed's Computer Details
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    Cape Town/South Africa
    386
    Default animate a hinge as sub-assembly in a an assembly
    Hi All,
    As you know a simple hinge has 2 parts. One leaf will attach to the door panel and the other leaf attach to the door frame. I have a whole hinge as an assembly file and I have the whole door in another assembly file using the assembled hinge in it.
    Is there any way to open the door and at the same time that side of the assembled hinge which attached to the door panel rotate as well?
    Cheers
    AJ
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    Quote Originally Posted by alijahed View Post
    Hi All,
    Cheers
    AJ
    Why not just bring in the individual hinge components into the door assembly and constrain them there?
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Right click on the hinge sub-assembly and set to Flexible.
    If you can't figure it out - zip and attach your assembly here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    Perfect! Thanks a lot JD.
    I am getting there...
  1. making a sub assembly part of the main assembly
    By bigben1103 in forum Autodesk Inventor
    Last Post: 5th May 2013, 11:57 am
  2. Assembly into another assembly in inventor
    By Irshaad in forum Autodesk Inventor
    Last Post: 21st Apr 2010, 08:26 pm
  3. Replies: 4
    Last Post: 3rd Oct 2009, 05:42 pm
  4. Assembly
    By h0wi3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Aug 2008, 05:20 am
