Drill Bit Cut
bigben1103
Hello Everyone,
I am drawing an adjustable drill stop. I have basically chamfered a cylinder to create a point. I know what the sweep profile looks like, I just cannot seem to angle the plane to be tangent with the chamfer. Being as I am on a school computer, I am unable to attach a picture or a file (I have tried). Any suggestions?
-Max
Make one of your origin planes visable
select make workplane button from ribbon
select face of chamfer
Right Click and choose make point
select edge of chamfer and click
select edge of visible worokplane and click
You will now have a workplane tangent to the chamfer and perpendicular to the origin plane you used.
[ATTACH]26714[/ATTACH]
figured it out! I did not need an angled plane. I made a horizontal profile of the cuts and used the coil-cut command to take out the material. Thanks for the help!
Actually, you do - if you want to do it right. If you are just making a pretty picture, then you should be OK.
