Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2008
    Mar 2011
    3
    Default Importing Coordinates (or Dimensions) from MS Excel 2007 to Autocad 2008
    Hello,
    I am designing a RCC Dam and the shape of the dam is constant and will not change, but the dimensions of this shape are very likely to change depending upon hydraulic analysis.
    I have written a program (irrelevant, but I am using MathCad 14) that performs a stability analysis of a RCC Dam (based on elevations from the hydraulic analysis) and then exports the dam dimensions and coordinates to Excel.
    I am attempting to then take those coordinates (or dimensions) from Excel to create a 2-D dimensioned drawing of the Dam in AutoCAD.
    I have successfully linked the Excel spreadsheet containing these coordinates and dimensions to AutoCad tables in my drawing, but I am having trouble getting AutoCAD to update my drawing as these tables update with different coordinates and dimensions.
    I would like to have a drawing that is fully dimensioned (as the shape of the dam will not change), but that will update coordinates and dimensions as I pump out different dam dimensions from my stability analysis.
    Hope this makes sense, let me know if anything is unclear.
    Thanks!,
    Sublett
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    See if you can find an old excell to autocad example called "shaft" it dynamically updated as you changed the excell cell values, its around R12 though.
    Forum Newbie
    AutoCAD 2008
    Mar 2011
    3
    BIGAL,
    I have been unable to find the example, "shaft," you mentioned. Do you have any other advice?
    In other words, I would like to link values in an AutoCAD table to values of coordinates (or dimensions) of an existing drawing, such that, as those table values are changed, the coordinates and dimensions in the drawing will update.
    I have successfully overwritten dimensions using FIELDS and text override, but I would like to find a way to actually update the dimensions, so that the scale of the drawing will remain correct.
    Thanks for your help!,
    Sublett
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Post an image or a dwg of your dam the example I refered to changed the length of lines for an object. change in excel object changed, if you have points and dim two points moving a point the dim updates so you need a dynamic link for points to excell. I have done excel link but very basic stuff. Some one else may be able to help.
  5. #5
    Forum Newbie
    AutoCAD 2008
    Mar 2011
    3
    Here is an example set of coordinates that could define the dam:
    PLINE
    0.0,0.0
    0.0,141.9
    30.0,141.9
    30.0,131.9
    117.5,0.0
    0.0,0.0
    And here is the shape of the dam, which will not change. Only the dimensions will change.
  1. Coordinates from Excel to AutoCAD
    By TheStig in forum AutoCAD General
    Last Post: 13th Jul 2010, 03:40 pm
  2. Importing coordinates from Excel
    By Niz in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2010, 02:04 pm
  3. Importing database format coordinates to autocad 2007
    By Shayne17 in forum AutoCAD Beginners' Area
    Last Post: 22nd Aug 2009, 08:59 am
  4. importing x,y coordinates from excel to cad.
    By hallmbhall in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2008, 12:05 am
  5. coordinates ( dimensions) to excel
    By louislbernstein in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2007, 06:57 am
Tags for this Thread
