Open .dwg files from combobox with AutoCAD 2010 VBA
suwan116
Hey Guys!
Im new to AutoCAD and VBA. My task is to develop an autocad add on program that will allow a user to insert a customised project drawing frame. I have setup the userform where a user can click on the combo box and select a drawing frame (in this case A4, A4 Portrait, A3 and A1) and click the insert button, which will then display the frame in PaperSpace.
Currently i have used some code which enables me to bring up the drawing frame and display it in PaperSpace, however the code only allows me to bring up one of the frames. Im not sure how to change the code so the use can chose which frame they would like. Heres the code i have so far:
Private Sub CommandButton2_Click()
Dim myBlock As AcadBlockReference
Dim blockInsert(0 To 2) As Double
blockInsert(0) = -18
blockInsert(1) = -6
blockInsert(2) = 0
Set myBlock = ThisDrawing.PaperSpace.InsertBlock(blockInsert, "C:\Drawing Frame\A1_Frame.dwg", 1, 1, 1, 0)
End Sub
As you can see from the code, it will only bring up the A1 Frame. How could i edit this code so the end user could use the drop down to select a desired frame.
I hope this makes sence and hope you could help me with this.
Cheers!
You might be want to use something like:
Say you have the items in your Combo:
A1
A3
A4
A4 portrait
etc...
Here is the code snip
Option Explicit
'' your folder path here:
Const frameFolder As String = "C:\Drawing Frame\" '<--backslash at the end
Dim frameDwg As String
frameDwg = ComboBox1.Text '<-- get selected item
Dim dwgName As String
dwgName = frameFolder & frameDwg & "_Frame.dwg"
MsgBox dwgName
blockInsert(1) = -6
blockInsert(2) = 0
Set myBlock = ThisDrawing.PaperSpace.InsertBlock(blockInsert, dwgName, 1, 1, 1, 0)
ComboBox1.ListIndex = -1 '<--refresh combo
End Sub
And also, no offence, but as far as you just started with programming, so
forget about VBA and start to learn AutoLisp or VB.NET (or both of them
if you like it, coz VBA would not supported in the future AutoCAD releases)
Just IMHO
~'J'~
Hey, cheers for that, i shall give it a go!
And im doing this for an assignment. i dont think we can use vb.net or autolisp.
I keep getting a debug error with this bit of code:
You have to check if you created correct drawing name
I've added FileExist function,
see comments
''Go to Tools->References, add Reference to Microsoft Scripting Runtime
''Go to Tools->Options->General->Error Trapping frame check  "Break on Unhandled Errors" button
Option Explicit
Function FileExist(dwgName As String) As Boolean
   Dim txt As String
   Dim fs As Object
   Dim fl As Object
   Set fs = CreateObject("Scripting.FileSystemObject")
    On Error GoTo Err_Control
   Set fl = fs.Getfile(dwgName)
   If Not fl Is Nothing Then
   FileExist = True
   Exit Function
   End If
Err_Control:
   FileExist = False
End Function
Private Sub CommandButton1_Click()
dwgName = frameFolder & frameDwg & ".dwg" '<--build a full path of drawing here
MsgBox FileExist(dwgName)
End Sub
If Not FileExist(dwgName) Then
MsgBox "File:" & vbCr & dwgName & " does not exists"
Exit Sub
End If
MsgBox dwgName
blockInsert(1) = -6
blockInsert(2) = 0
End Sub
OMG! It worked!!! Wooooo! lol. Thanks very much for your help mate.
Just another thing, i can get the selected drawing frames to display in PaperSpace, but i have to manually navigate to the drawing by going to AutoCad then Layout 1.
Is there any code i could put at the end that takes the user to Paper Space, or do they do that manually?
Just from the memory : take look at
ThisDrawing.ActiveLayout
in the Help
With ThisDrawing
.ActiveLayout = .Layouts.Item("Layout1")
End With
Or
With ThisDrawing
.ActiveLayout = .Layouts("Layout1")
End With
~'J'~
Edited by fixo
code added
hey! i tried the code and It kinda works. Now i only need to click on autocad on the taskbar, and it will be on layout1. It doesnt automatically open autocad.
You have to read docs about document-level event handling
in this case you need intercept the AcadDocument_Activate event
I'm aware of that sorry
hey, i will do a search for this coding.
do you know a way to update the drawing, so if i launch the form agian it will insert new drawing and delete the previous frame.
After his block was inserted you could be to store its handle, say in Textbox field, that is easiest
in the current program
dim handStr as string
handStr=myBlock.Handle
TextBox1.Text=handStr
Then if you need to insert new one instead
you could be able to rich at old block using
HandleToObject method (see Help)
Don't remember exactly maybe something like
Dim oldObj as AcadObject ' or AcadEntity perhaps
Set oldObj=Thisdrawing.HandleToObject(Trim(TextBox1.Text))
oldObj.Delete
Set oldObj=Nothing
~'J'~
Edited by fixo
spell check
I used this bit of code to auto show layout1
With ThisDrawing
.Application.Application.GetAcadState
End With
However im struggling with the update code.
  • 3 weeks later...
I am new to this and have exactly the same application. Can you show your complete work here, starting with creating your combobox to inserting seletion to the drawing.
Thanks
