you can select xref only and then click the "invert filter" box bottom left of dialog box - any good?
Hello!
I have a problem/ question!
My company uses tons of Xrefs - wonderful, however problem comes when having to navigate through 100's of layers to get to the main drawings layers. So I tried using the layer filters to just show my main drawings layers. Here is the problem, I you can select show all layers, not good, can select just the xrefs (show all of them or show just one of them, etc...), or you can show just the used layers - I tried that, but when you create a new layer it is not included in that filter. I tried setting up a custome layer filter, however, I don't know how to right the name or what selection to make that would allow me to exclude a set of layers. Anyone know how to fix this?
excelent! you know, if I had just looked around a bit! Thanks!!!!!!
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
well, I have found an issue with the invert filter - it doesn't invert the filter for the drop down layer tool in the ribbon.
I will have to ask our CAD manager to see if he would put that in our menu.
Create a new filter, and in the "NAME" column, enter (without the quotes) "~*|*"
The tilde ~ means NOT
The asterisk * is a wildcard
Every Xref layer will have a pipe | in the name, so filtering for names that don't have a pipe | in them will leave just native layers showing.
Note that the pipe | is not a lowercase L. It is a vertical line usually created with shift+\
Hope this helps.
I will give that a shot!
Kenboldt - it works perfectly!
nestly - I had tried that before, for some reason it doesn't work.
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
