Results 1 to 6 of 6
    Full Member
    AutoCAD 2010
    Sep 2010
    UAE / India
    55
    Default How to add Block Description
    hi,
    Is it possible to add Block Description while creating A new Block using LISP?
    eg.
    Code:
    (defun c:OB(/ ssblk)
       (setq ssblk (ssadd))
          (command "_rectangle" (list -0.35 0.00 0.00)(list 0.35 0.70 0.00))
           (setq ssblk (ssadd (entlast) ssblk))
          (command "_Line" (list -0.35 0.00 0.00)(list 0.35 0.70 0.00)"")
          (command "_Line" (list -0.35 0.70 0.00)(list 0.35 0.00 0.00)"")
          (Command "CHPROP" ssblk "" "LA" "0" "")
          (command "-BLOCK" "BSO" (list 0 0 0) ssblk "")
    I like to add Block description ( Bottom Slab Opening ) in this block please help me...
    Thanks and regards
    bijoy
    Senior Member Ahankhah's Avatar
    Ahankhah's Computer Details
    Windows XP
    AutoCAD 2012
    Jun 2010
    Tehran, Iran
    430
    Mehrdad Ahankhah مهرداد آهن خواه
    www.IranCAD.com
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    Some food for thought:
    Code:
    (defun c:OB nil
      (if
        (or (tblsearch "BLOCK" "BSO")
            (entmake
              (list
                (cons 0 "BLOCK")
                (cons 2 "BSO")
                (cons 8 "0")
                (list 10 0. 0. 0.)
                (cons 70 0)
                (cons 4 "Bottom Slab Opening")
            (entmake
              (list
                (cons 0 "LWPOLYLINE")
                (cons 100 "AcDbEntity")
                (cons 100 "AcDbPolyline")
                (cons 8 "0")
                (cons 90 4)
                (cons 70 1)
                (list 10 -0.35 0.0)
                (list 10  0.35 0.0)
                (list 10  0.35 0.7)
                (list 10 -0.35 0.7)
            (entmake
              (list
                (cons 0 "LINE")
                (cons 8 "0")
                (list 10 -0.35 0.0 0.0)
                (list 11  0.35 0.7 0.0)
            (entmake
              (list
                (cons 0 "LINE")
                (cons 8 "0")
                (list 10 -0.35 0.7 0.0)
                (list 11  0.35 0.0 0.0)
            (entmake
              (list
                (cons 0 "ENDBLK")
                (cons 8 "0")
        (entmakex
          (list
            (cons 0 "INSERT")
            (cons 2 "BSO")
            (list 10 0. 0. 0.)
    Will create the block definition if not present in the drawing and insert a block at 0,0,0.
    For a reference of what all the DXF codes mean, see here.
    Or in Visual LISP:
    Code:
    (defun c:OB ( / acdoc ) (vl-load-com)
      (setq acdoc (vla-get-activeDocument (vlax-get-acad-object)))
      (if (not (tblsearch "BLOCK" "BSO"))
          (lambda ( block / poly line1 line2 ) (vla-put-comments block "Bottom Slab Opening")
            (setq poly
              (vlax-invoke block 'addlightweightpolyline
               '(-0.35 0.0 0.35 0.0 0.35 0.7 -0.35 0.7)
            (vla-put-closed poly :vlax-true)
            (vla-put-layer  poly "0")
            (setq line1 (vlax-invoke block 'addline '(-0.35 0.0 0.0) '(0.35 0.7 0.0)))
            (setq line2 (vlax-invoke block 'addline '(-0.35 0.7 0.0) '(0.35 0.0 0.0)))
            (vla-put-layer line1 "0")
            (vla-put-layer line2 "0")
          (vlax-invoke (vla-get-blocks acdoc) 'add '(0. 0. 0.) "BSO")
      (vlax-invoke
        (vlax-get-property acdoc
          (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace)
        'InsertBlock '(0. 0. 0.) "BSO" 1. 1. 1. 0.
    Lee Mac Programming
    Just another Swamper
    Full Member
    AutoCAD 2010
    Sep 2010
    UAE / India
    55
    Thank you so much lee & ahankhah and i would like to learn VISUAL LISP is their is any simple tutorial please let me know
    thanks & regards
    bijoy.v.m
  5. #5
    Windows XP
    AutoCAD 2012
    Jun 2010
    Tehran, Iran
    430
    A very good reference is here:
    http://lee-mac.com/tutorials.html
    www.IranCAD.com
  6. #6
    Full Member
    AutoCAD 2010
    Sep 2010
    UAE / India
    55
    Thanks Ahankhah...
  1. block description field
    By ARGV in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Nov 2012, 10:07 am
  2. Edit Block Description Without Exploding
    By trentmoore in forum AutoCAD Beginners' Area
    Last Post: 9th Jun 2011, 04:56 pm
  3. Edit Block Description
    By AQucsaiJr in forum AutoCAD General
    Last Post: 19th Oct 2009, 09:27 pm
  4. block description in vba
    By Jaap in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jan 2009, 02:51 pm
  5. Change the block description?
    By stevsmith in forum AutoCAD General
    Last Post: 29th Sep 2008, 12:33 pm
