Results 1 to 4 of 4
Thread: Pdfattach
    Forum Newbie
    RMC46835's Computer Details
    W7x64
    IT supplied it
    No tsure but it's fast
    24 G
    Nividea
    Electronic Hard drive
    40" and 32" Sharp LED
    MEP 2011
    Apr 2011
    Fort Wayne, Indiana
    4
    Default Pdfattach
    When using PDFATTACH command I'm able to manipulate the PDF underlay but my workstation performance slows down to an unaccptable level and often locks up cuasing me to lose work.
    I'm using the overlay to overlay piping systems design.
    Size of PDf is less than 1MB
    Workstation is used primarily for 3d modeling and works very fast in that area so 2D overlay should not act like this.
    This happens no matter what scale I set on the attachment.
    I put the PDF on it's own layer to allow toggling on/off
    Locking layer or not makes no diference.
    Plotted drawings with overlay look fine, it's just the perfomance that is a problem.
    Can anyone help?
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,586
    PDF's for some reason bring a huge performance hit when attached to a drawing. I do not know why other than it's a true statement. That's why I always convert to a 2-Bit TIFF file (aka monochrome TIFF).
    http://pdf.my-addr.com/free-online-p...ff-convert.php
    Here is a link to an online converter that works great for small batches. A drawback that could be minor, or major, is if you utilize Vectorized PDF for the PDFOSNAP tools, you will lose this functionality obviously. Hope this helps.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Forum Newbie
    W7x64
    IT supplied it
    24 G
    Nividea
    MEP 2011
    Apr 2011
    Fort Wayne, Indiana
    4
    Thank you Sir,
    I'll try this. I believe there is a function in Adobe Pro that allows some sort of conversion to TIFF but I'm not familiar with the 2bit term. I'll let you know if it works.
    RMC
    Forum Newbie
    W7x64
    IT supplied it
    24 G
    Nividea
    MEP 2011
    Apr 2011
    Fort Wayne, Indiana
    4
    Default It worked like a charm
    I saved the PDF as a Tiff using Adobe Pro, not sure if it was a monochrome version but whateever it was it worked. I used IMAGEATTACH and the perfrmance is as fast as normal.
    Thanks again from what appears to be fellow pipefitter type.
    R Current
    Current Mechanical
    Fort Wayne IN.
