ReMark Posted April 5, 2011 Share Posted April 5, 2011 The ability to close a drawing by clicking on the "X" in the upper right hand corner sometimes disappears entirely and the only way to bring it back is to change workspaces. Working in a 3D workspace and some of my extruded objects appear dashed as though I had selected them when I hadn't. A Regen clears it up temporarily. Despite turning Dynamic UCS off (first thing I did when I switched to a 3D workspace) the UCSicon acts as though the feature is still enabled. No solution found yet. It is quite aggravating. Leftover from the last release or two: Online Help still sucks and the distraction of the ViewCube. Anyone else experiencing gremlins? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 5, 2011 Share Posted April 5, 2011 I see Autodesk still likes to release yearly versions even though the bugs from the last few years still go unsolved and even toss in a few new ones. I am really getting tired of the help feature on 2011. I use Bing or Google and getter better results. What has Autodesk's response been on these bugs and glitches? Pretty sure I will not be moving up to AutoCAD 2012 anytime soon if at all. I should be moving on to Bentley AutoPLANT, Sieman FactoryCAD or AutoCAD Plant 3D in the near future. I have had problems with 2011, but have attributed those to the graphics card on my machine. The ViewCube I can live with in Model, but seems to get in the way in viewports. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Another oddity. I created a rectangle on layer "0" (default color: white) that I then extruded. I moved this to another layer that had a different color. The object would not take on the color property of that layer. Even using the Match Properties command I could not "force" the object to assume the color. It remained white. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 5, 2011 Share Posted April 5, 2011 Have you checked the defaults for the properties settings dialog box? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Have you checked the defaults for the properties settings dialog box? Yep...first thing I did. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 5, 2011 Share Posted April 5, 2011 Another oddity. I created a rectangle on layer "0" (default color: white) that I then extruded. I moved this to another layer that had a different color. The object would not take on the color property of that layer. Even using the Match Properties command I could not "force" the object to assume the color. It remained white. Which workspace were you using when this happened? I experienced a similar phenomenon in 2010. Changed to Autocad classic, and the problem disappeared. Switched back to the 3d modeling workspace, but was unable to recreate the problem. It's happened a couple of times, but its nothing I've been able to recreate intentionally. Never happens in the "classic" workspace however. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 And now this. Opened a drawing (2D piping and instrumentation diagram) I last edited and saved in AutoCAD 2010. I get an AutoCAD Error message window with the words: Unrecognizd version and cannot be read. Managed to somehow bluff my way through it but when I went to close the drawing the error message returned. 2012 has a problem reading 2010 file format? Wow! That's a hoot. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Which workspace were you using when this happened? I experienced a similar phenomenon in 2010. Changed to Autocad classic' date=' and the problem disappeared. Switched back to the 3d modeling workspace, but was unable to recreate the problem. It's happened a couple of times, but its nothing I've been able to recreate intentionally. Never happens in the "classic" workspace however.[/quote'] I was in the 3D Modeling workspace at the time. The workspace is one of the 2012 defaults. No changes were made to it. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 5, 2011 Share Posted April 5, 2011 I just stay in the classic one now. It seems to cure several of the evils associated with the ribbon and it's "improvements". Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 5, 2011 Share Posted April 5, 2011 You are going to have to open all your Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 You are going to have to open all your May your nether-regions be infested with a swarm of sand fleas. Curses! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 5, 2011 Share Posted April 5, 2011 May your nether-regions be infested with a swarm of sand fleas. Curses! Speaking of warm and sand, I should go to the beach this weekend to cool down. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 5, 2011 Share Posted April 5, 2011 Just buy one of these, and all your problems will be solved: http://www.cray.com/Products/CX/Systems/CX1.aspx Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Just buy one of these' date=' and all your problems will be solved:http://www.cray.com/Products/CX/Systems/CX1.aspx[/quote'] I think my new work system (see Computer Details to left) is just about right for the work I do but if I every get invited on Jeopardy I'll take another look at the Cray CX1 Jack. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 5, 2011 Share Posted April 5, 2011 Another oddity. I created a rectangle on layer "0" (default color: white) that I then extruded. I moved this to another layer that had a different color. The object would not take on the color property of that layer. Even using the Match Properties command I could not "force" the object to assume the color. It remained white. Are in a visual style other than 2D? Quote Link to comment Share on other sites More sharing options...
rkent Posted April 5, 2011 Share Posted April 5, 2011 The ability to close a drawing by clicking on the "X" in the upper right hand corner sometimes disappears entirely and the only way to bring it back is to change workspaces. Working in a 3D workspace and some of my extruded objects appear dashed as though I had selected them when I hadn't. A Regen clears it up temporarily. Despite turning Dynamic UCS off (first thing I did when I switched to a 3D workspace) the UCSicon acts as though the feature is still enabled. No solution found yet. It is quite aggravating. Leftover from the last release or two: Online Help still sucks and the distraction of the ViewCube. Anyone else experiencing gremlins? Turn the viewcube off in Options, 3D modeling... ? Help is getting "worser and worser". Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Are in a visual style other than 2D? The visual style at the time was 2D wireframe. I don't find the mass of lines confusing as some do. I only switch to Conceptual or Realistic when I want to check something. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2011 Author Share Posted April 5, 2011 Turn the viewcube off in Options, 3D modeling... ? Will do. Thanks rkent. I had completely forgotten about that feature. A pox on the ViewCube and on Help. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 5, 2011 Share Posted April 5, 2011 Sounds like all of those (except help) are graphics card related. I can't reproduce the problems here, so far. Time to start up the nvidia controls and start tweaking. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 5, 2011 Share Posted April 5, 2011 Will do. Thanks rkent. I had completely forgotten about that feature. A pox on the ViewCube and on Help. In 2012 you can use the viewport controls symbol while in a viewport or in model space, upper left [+] or [-] symbol, choices will show once selected. Quote Link to comment Share on other sites More sharing options...
