Results 1 to 4 of 4
    Full Member redbeardcad's Avatar
    AutoCAD 2012
    Dec 2009
    Central PA
    56
    Angry Drawing scale snafu
    Is there such a thing that can change drawing units to the correct scale?
    Here's what I mean. I am tasked with keeping all our facility drawings up to date.
    I get civil drawings in for site work, architectural drawings for our buildings and mechanical drawing for all our production machines. As things change or move I am supposed to update drawings.
    The big boys (and girls) upstairs want to see a drawing that "has it all". "Afterall don't you just click a few buttons?"
    So civil is decimal feet, building is feet and inches, and most machines are metric.
    My back ground is construction so dealing in feet-inches is easy for me. I only do this part time so I am not a CAD wizard. I'm getting very frustrated, and need to go to the gym to punch some one, I mean thing.
    Any suggestions are appreciated.
    Thank you.
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Do you need to convert each drawing so they all use the same unit of measurement, because if not, it's simply a matter of xreffing them together. For example, if your metric machine drawing is designated as metric, and you xref it into an imperial drawing, it will automatically be scaled properly and when you measure or dimension the machine, the dimension will be imperial.
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Have you tried _UNITS>Insertion Scale>Units to scale inserted content?
    AutoCAD 2012
    Dec 2009
    Central PA
    56
    Thanks, I'll give it a try.
  1. understanding drawing scale and scale factor
    By flyingal in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2012, 06:30 pm
  2. help-drawing scale
    By lima oscar in forum AutoCAD Beginners' Area
    Last Post: 12th Nov 2009, 03:35 pm
  3. Drawing scale/paper scale
    By loopfish in forum AutoCAD General
    Last Post: 19th Mar 2009, 05:24 pm
  4. How Do I Scale Drawing With No Obvious Scale, But Looks Like It Has One?
    By winstone66 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Mar 2009, 02:25 pm
  5. Terrain Model Explorer SNAFU
    By Allen TL in forum Civil 3D & LDD
    Last Post: 30th Oct 2008, 01:30 am
