Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Junior Member
    Architecture 2012
    Apr 2011
    21
    FORGET IT!!!!!! Nobody knows.
  2. #12
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Dont give up
    the "AeccXUiLand.AeccApplication.8" refers to a version of Civ3d 2011 you have to know what it is called to get inside the architecture database maybe "AeccArchi.AeccApplication.8" ? try Theswamp.org also.
    Check out your "sample" directory it should have a directory called say d:\autocad 2011\sample\archi API\com this will have vba etc examples of code to access the database.
    Just do a VBAMAN and load the dvb, read the Reame.txt first to see what it does.
  3. #13
    Junior Member
    Architecture 2012
    Apr 2011
    21
    Found the examples, but I don't know what I'm looking at. I just know enough to be dangerous and I'm really dangerous!
  4. #14
    Junior Member
    Architecture 2012
    Apr 2011
    21
    OK, how about this. Created a routine that will start a lisp routine. With the lisp routine, I hope to be able to get the selection set that I need so as to compare all the object with on another so that like objects will have the same tag number, and if the like styles change in the slitest, it will change the tag number. Now if I achieve this, how do I get the result back into the VBScript so I can input itinto the schedule table? Any takes on this?
  1. Drawing 3D Steel Beam
    By Sparky in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Dec 2009, 05:18 pm
  2. Structural Beam MEP
    By dsibbo in forum MEP
    Last Post: 18th Nov 2008, 09:18 pm
  3. 3D Arc for Help with Curved Sloping Beam
    By steelstacker in forum AutoCAD Beginners' Area
    Last Post: 12th Oct 2008, 06:28 am
  4. Cut beam with beam Radiused/Straight Beams
    By mattbarb in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Apr 2008, 04:42 pm
  5. Beam Dimensions
    By Thaumaturge in forum Blocks, Images, Models & Materials
    Last Post: 13th Sep 2007, 10:19 am
