How to open and close a Folder by visual lisp?
I have a Path (ex:"D:\\PROJECTS\2010\")
Thanks.
Lee helped me
But I still can't Close a FolderCode:(defun Explore ( Directory / Shell result ) (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application")) (setq result (vl-catch-all-apply 'vlax-invoke (list Shell 'Explore Directory))) (vlax-release-object Shell) (not (vl-catch-all-error-p result)) )![]()
this may help
Code:;;;CADALYST 10/06 Tip2158: Directory.lsp Directory (c) Mark Newman ;;; Created by Mark Newman : June 2002 ;;; ;; ---- ;; ---- (DEFUN C:DIRECTORY (/) (STARTAPP "EXPLORER" (GETVAR "DWGPREFIX")) (PRINC) ) ;; ---- ;; ----
I have needed a way for our users to open files in a specific folder. Not the last one accessed or the folder where the particular open file originated. Trying to use the Open command did not work so I used "startapp" like this to open Explorer in the T:\ drive which is mapped to a server location:
This works but I'd like to have only the *.dwg file appear in the list and adding \*.dwg to the above command has no affect on it.Code:^C^C^P(startapp "Explorer T:")
It's deja vu, all over again.
Code:(getfiled "" "T:\\" "dwg" 16)
Lee Mac Programming
Just another Swamper
Lee,
Thanks. I had to double check my syntax, but that is working. Thanks again.
BTW - are you getting to see any of the Olympic Games over there?
Lee Mac Programming
Especially the Netherlands Women's Field Hockey team. Hubba hubba!
To complete this here is what I ended up doing:
Works pretty good. Thanks again.Code:(defun c:open4chk (/ fname) (vl-load-com) (setq fname (getfiled "" "T:/" "dwg" 16)) (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fname)) )
Indeed, or the beach volleyball!
Alternatively, consider:
Code:(defun c:open4chk ( / f ) (if (setq f (getfiled "" "T:/" "dwg" 16)) (startapp "explorer" f) ) (princ) )
Lee Mac Programming
