Results 1 to 6 of 6
    Full Member
    AutoCAD 2007
    Mar 2011
    26
    Default Inventor dynamic simulation
    Dear Sir;
    I am working a manufacture camshaft plant in Turkey.Could you help me please for inventor dynamic simulation. I want to do a simular simulation like a following adres.
    http://www.youtube.com/watch?feature...&v=x07DV2Z9_MQ
    But I couldn’t yet.Because I have a mistake defined to joint.Normaly flat follower has to move together by cam.But it has no moved.Can you prepare this simulation for me or explain my mistake.
    Best regards…
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    ses4
    you have posted in the wrong forum. You should post this in the Inventor forum.
    Zip and attach your assembly there.
    I do not see a Spring/Damper/Jack Force (expand your External Loads node in the browser)
    Full Member
    AutoCAD 2007
    Mar 2011
    26
    Dear JD Mather thanks for your answer.I want to converter cams profile value roller follower to flat follower but I did'nt yet.Could you help me please.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Do you know the desired displacement profile?
  5. #5
    Full Member
    AutoCAD 2007
    Mar 2011
    26
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You spreadsheet list of coordinates is not a displacement diagram. And it appears to have been generated for a round follower.
    What is the rise, fall, dwell and acceleration profile for your cam? (you can create this using the Cam Generator even though your follower will not be round - post a screenshot of your displacement diagram)
  1. Pin Joint Problems with Inventor Dynamic Simulation
    By Richard Wardle in forum Autodesk Inventor
    Last Post: 8th Feb 2011, 03:11 am
  2. Please help with Inventor simulation
    By maceng in forum Autodesk Inventor
    Last Post: 29th Apr 2010, 10:18 pm
  3. Inventor dynamic simulation
    By jusuph in forum Autodesk Inventor
    Last Post: 10th Mar 2010, 05:56 pm
  4. Dynamic Simulation problem in Inventor Professional 11
    By john2009 in forum Autodesk Inventor
    Last Post: 7th Jan 2009, 05:31 am
  5. Dynamic Simulation Information
    By Lazer in forum Autodesk Inventor
    Last Post: 29th Oct 2007, 07:44 pm
