Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Nuts and Bolts
    Forum Newbie
    not specified
    Nov 2005
    2
    Default Nuts and Bolts
    I was wondering if there was a way in AutoCAD 2006 to thread a bolt in 3D.
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2014
    Aug 2005
    Northants, England
    1,572
    This may help
    http://cadtutor.net/forum/viewtopic.php?t=5603
    I also remember fuccaro done a screw with a thread once, have a search as he may have gave a tutorial on how it was done.
    EDIT: Found it http://cadtutor.net/forum/viewtopic....t=screw+thread
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    Here's an old old lisp I wrote 10+ years ago. Wow am I getting old.....
    [code];ΙΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝ ΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝ»
    ;Ί 3DScrew.Lsp Version 1.2 Sep 24, 1994 Ί
    ;Ί Draw A 3D Screw Tread Ί
    ;ΘΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝ ΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΌ
    ;================== Start Program ======================================
    (princ "\nLoading 3DScrew v1.2 ") ;Program Loader
    (setq 3DScrew nil sp_c 1) ;Reset Program Name
    ;%%%%%%%%%%%%%%%%%% Macros %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
    (defun PDot () (princ ".")) ;Print Dot
    (defun Spin () ;Spinning
    (setq sp_c (1+ sp_c)) ;Dashes
    (write-char '8) ;For Display
    (princ (nth (rem sp_c 4) (list "|" "/" "-" "\\"))))
    (defun BkSp () (write-char '8)) ;Back Space
    (defun AtoR (a) (* pi (/ a 180.0))) ;Angle To Radian
    (defun RtoA (r) (/ (* r 180.0) pi)) ;Radian To Angle
    (defun Beep (/ f) (setq f (open "con" "w")) ;Print Hex 7
    (write-char '7 f) (close f)) ;To CON
    (defun Err (e) (beep) ;Augmented
    (princ (strcat "\nError: " e)) ;Error
    (quit)) ;Routine
    ;%%%%%%%%%%%%%%%%%% Sub Routines %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
    (PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++
    ;Mode Variables m_l SetList m_s NewSetting m_n OldName m_v OldValue
    (defun st_smd () ;Define st_smd
    (command "UNDO" "MARK") ;Set An Undo Mark
    (setq m_v nil m_n nil ;Reset Name & Value
    m_l (list "CMDECHO" "BLIPMODE" "HIGHLIGHT" "SPLFRAME")
    m_s (list 0 0 1 0) ;Setup Modes
    olderr *error* ;Get Old Error
    *error* (lambda (s) ;Set Error So That
    (cond ((= s "Function cancelled")) ;If Cancel Or
    ((= s "quit / exit abort")) ;Abort Exit Clean
    ((princ (strcat "\nError: " s)))) ;Else Print Error
    (st_rmd))) ;Return Modes
    (foreach x m_l (setq m_v (cons (getvar x) m_v);Get Value
    m_n (cons x m_n))) ;And Variable
    (mapcar 'setvar m_l m_s)) ;Set New Modes
    (PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++
    (defun st_rmd () ;Define st_rmd
    (setq *error* olderr) ;Reset Error
    (mapcar 'setvar m_n m_v) ;Reset Modes
    (prin1)) ;Exit Clean
    (PDot);************ Main Program ***************************************
    (defun 3dscrew (/ nang elv ctr dia dis ang rad trd sec ris base rev
    p2 p3 pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8
    m_n m_v m_s m_l olderr)
    (st_smd)
    ;------------ Get User Input -------------------------------------------
    (setq ctr (getpoint "\nCenter Of Screw:.... "))
    (setq dia (getreal "\nOutside Screw Diameter:... "))
    (setq trd (getreal "\nNumber Of Threads Per Inch:... "))
    (setq tag (getangle "\nThread Cut Angle:... "))
    (setq sec (getint "\nEnter Number Of Sections To Draw Per Thread:... "))
    (setq rev (getreal "\nNumber of Threads To Draw <1>:... "))
    ;------------ Set Constants --------------------------------------------
    (if (= rev nil)(setq rev 1)) ;Default To 1 Revolution
    (setq rad (* dia 0.5)) ;Calculate Radius
    (setq base (caddr ctr)) ;Set Base Elevation
    (setq old base) ;Set Last Elevation
    (setq ris (/ 1.0 trd)) ;Calculate Rise Per Thread
    (setq elev (+ base (/ ris sec))) ;Next Elevation
    (setq ang (/ 360.0 sec)) ;Angle Per Section
    (setq nang (/ 360.0 sec)) ;Next Angle
    (setq ird (- rad (/ (* ris 0.5) ;Get Inside Radius
    (/ (sin tag) (cos tag))))) ;As A Percentage
    (setq irad (/ ird rad)) ;Of Outside Radius
    ;------------ Setup First Segment --------------------------------------
    (setq pt1 (list (+ (car ctr) rad) (cadr ctr) base)) ;Set Point1
    (setq pt4 (list (* irad (car pt1)) ;Set Point4
    (* irad (cadr pt1))
    (+ base (* 0.5 ris))))
    (setq p2 (polar ctr (* pi (/ nang 180)) rad)) ;Calculate XY2
    (setq p3 (polar ctr (* pi (/ nang 180)) (* rad irad))) ;Calculate XY3
    (setq pt2 (list (car p2) (cadr p2) (+ base (/ ris sec))));Set Point2
    (setq pt3 (list (car p3) (cadr p3) (+ old (* 0.5 ris)))) ;Set Point3
    (setq pt5 (list (car pt1) (cadr pt1) (+ base ris))) ;Set Point5
    (setq pt6 (list (car pt2) (cadr pt2) (+ elev ris))) ;Set Point6
    (setq pt7 (list (car ctr) (cadr ctr) (+ elev ris))) ;Set Point7
    (setq pt8 (list (car ctr) (cadr ctr) (+ base ris))) ;Set Point8
    ;------------ Draw Segments --------------------------------------------
    (repeat (fix (* sec rev)) ;Draw
    (command "3DFACE" pt1 pt2 ;Visible
    pt3 pt4 ;Thread
    pt5 pt6 "") ;Faces
    (command "3DFACE" "I" pt5 ;And
    "I" pt6 ;Hidden
    "I" pt7 ;Inner
    "I" pt8 "") ;Faces
    ;------------ Setup Next Segment ---------------------------------------
    (setq nang (+ nang ang)) ;Increase Angle
    (setq pt1 (list (car pt2) (cadr pt2) elev)) ;Set Point1
    (setq pt4 (list (car pt3) (cadr pt3) (+ old (* 0.5 ris))));Set Point4
    (prompt (strcat "\nWorking On Elevation: " (rtos elev 2 4)))
    (setq old elev) ;Last Elev
    (setq elev (+ elev (/ ris sec))) ;Outside Elev
    (setq inelev (+ elev (* 0.5 ris))) ;Inside Elev
    (setq pt2 (list (car p2) (cadr p2) elev)) ;Set Point2
    (setq pt3 (list (car p3) (cadr p3) (+ old (* 0.5 ris))));Set Point3
    (setq pt5 (list (car pt1) (cadr pt1) (+ old ris))) ;Set Point5
    (setq pt8 (list (car ctr) (cadr ctr) (+ old ris))) ;Set Point8
    ) ;End Repeat
    (st_rmd)) ;Return Modes
    (PDot);@@@@@@@@@@@@ Load Program @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    (defun C:3DScrew () (3DScrew)) ;Make Command
    (and 3DScrew ;Resident
    (repeat 25 (BkSp)) ;Confirm
    (prompt "3DScrew Defined \n")) ;Loading
    (prin1) ;Else Display Errors
    ;ΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝ End Program ΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝΝ
    &#91;code&#93;
    The beep thingy was a real DOS call. -David&#91;/code&#93;
    R12 (Dos) - A2K
    Forum Newbie
    not specified
    Nov 2005
    2
    Hey thanks a lot, I'm going to go experiment right now.
  5. #5
    Full Member joemaddigotz's Avatar
    joemaddigotz's Computer Details
    Windows XP 64.Bit
    ECS NFORCE 570-SLIT-A V5.1
    INTEL PENTIUM D DUAL CORE 3.0.
    4.0GB DDR 2
    NVIDIA GEFORCE 9500GT OC w/ 1GB MEMORY
    160GB, I know it's weak.
    Simple HP 15" LCD
    AutoCAD 2006
    Jan 2009
    Chicago, Illinois
    43
    No luck with the two links posted above - they both can not be found on the site.
    I was really hoping to see more threads on making threads lol...
    I am surprised but definatly not sure with AutoCAD 2006 where to begin.
    I have my cylinder made for the clamp - I just need someway of threading it along with the ring around the clamp..
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    Do a search of the forum on "threaded bolt". The topic has been discussed many times. Some of the threads contain links to other sites where the entire process of creating a threaded bolt is explained both in words and pictures. One such source would be Ellen Finkelstein's website.
  7. #7
    Windows XP 64.Bit
    4.0GB DDR 2
    Simple HP 15" LCD
    AutoCAD 2006
    Jan 2009
    Chicago, Illinois
    43
    It's quite amazing however - I have already exhausted all of my search options. I always search the threads and internet for help first -
    I am using AutoCAD 2006 - where as Finklestein's is using a command "Helix" which I do not have on my version of AutoCad.
    I could not find any resource that would help me with 06..
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    We've already covered this topic (Helix.lsp) in another thread. Visit CADTutor's AutoLISP Archive forum.
  9. #9
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
  10. #10
    Super Member SuperCAD's Avatar
    SuperCAD's Computer Details
    Win7 Professional 64bit
    HP Z420
    32G
    NVIDIA Quadro 4000
    150GB SSD
    1TB HDD
    LG W2353VP & LG W2343T
    Manufacture
    SuperCAD's Discipline Details
    CAD Manager
    Manufacture
    Design custom cabinetry and fixtures for retail and food service businesses.
    AutoCAD 2014
    Sep 2008
    WI, USA
    622
    That tutorial missed a step or two. Those threads sucked (they weren't aligned properly).
    Chuck Norris counted to infinity...
    Twice.
