Dear Cad Tutor
I'll really appreciate if you explain me how to divide a 3D polyline into "n" equal segments and export to a txt or cvs file.
Thanks a lot.
Try this code
This will write all measured points include start and end points
to csv file
You'd be easily save it then as .xls
Code:;;write 3dpoly points to csv (defun C:pcd(/ cnt datafile dimz en ent num filename pline pt pt_list step ) (vl-load-com) (setq dimz (getvar "dimzin")) (setvar "dimzin" 3);<-- change to suit (if (and (setq num (getint "\n\tEnter a number of divisions: ")) (setq ent (entsel "\n\tSelect polyline >> ")) (eq "POLYLINE"(cdr(assoc 0 (entget (setq en(car ent))))))) (progn (setq pt_list nil) (setq pline (vlax-ename->vla-object en)) (setq step (/ (vla-get-length pline ) num)) (setq pt_list nil) (setq pt_list (cons (vlax-curve-getstartpoint pline) pt_list)) (setq cnt 0) (repeat (1- num) (setq pt (trans (vlax-curve-getPointAtDist pline (* (setq cnt (1+ cnt)) step) ) 0 1 ) ) (setq pt_list (cons pt pt_list)) ) (setq pt_list (cons (vlax-curve-getendpoint pline) pt_list)) (setq pt_list (reverse pt_list)) (setq filename (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname"))".csv") ) (setq datafile (open filename "w")) (setq i 1) (foreach pt pt_list (write-line (strcat (itoa i) (chr 9);<--tab delimited, (chr 44) - comma delimited (rtos (car pt)2 3);<--precision 3 decimals (chr 9);<--tab delimited, (chr 44) - comma delimited (rtos (cadr pt) 2 3) (chr 9);<--tab delimited, (chr 44) - comma delimited (rtos (caddr pt)2 3)) datafile) (setq i (1+ i)) ) (close datafile) ) ) (setvar "dimzin" dimz) (princ) ) (princ "\n\t=== Type PCD to execute ===") (prin1)
The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
