What do you mean by not rotate? How are you inserting your symbols? Is this a P&ID question or AutoCAD?
When placing symbols on flow lines, How do you make them not rotate automatically? It seems so minor but its such a big headache! I've been messing around with it for a couple hours now and can't find the setting to change this. Any help would be greatly appreciated!
-Gary
It's P&ID, and it automatically rotates when you place it on a vertical line where the text reads bottom to top. I just exploded it and it worked but if there is a setting I can change to keep me from having to explode this that will be great.
Are you using the Tool Palettes to gain access to the symbol? Is it merely a block? If so, have you tried right clicking the symbol and selecting Properties to see extra features the tool may have?
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
Yea I'm using the tool palette and I've tried looking through properties but no luck. It's ok though I will just explode them when I need to place it on a vertical line. Thanks for the help!
It sounds like dynamic blocks are being used.
It is not a good idea to be exploding them.
The order of the attributes can be changed.
I doubt it's a dynamic block. Probably an AEC object.
