Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I still heavily doubt it's a standard block. I bet anything it's an AEC Object.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  2. #12
    Full Member
    Jach's Computer Details
    I got 2 screens yeah!
    P&ID 2014
    Feb 2012
    Planet Earth
    36
    if it is an standard, AutoCAD P&ID block, you edit it with right clicking on your project name and then take properties. now there will be a "tree" follow this path: P&ID DWG setting -> P&ID Classs Settings -> Engineering Items -> Equipment -> Pumps -> Centrifugal Pump
    now you can see the properties and in the top you will see a preview of the block.
    To the right of that preview the is some options, choice Edit Block.
    now you can remove the 2 Point Parameters and it save. and this specific symbol will not rotate in the future.
    NOTE! even if u regret what you have done, you can easy put the parameter ín again with the same names.
  1. how to make threaded rod inside a cylinder and then rotate it ?
    By alnabhani in forum Autodesk Inventor
    Last Post: 1st May 2010, 03:39 pm
  2. Rotate around a lines midpoint
    By Organic in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Apr 2009, 11:05 pm
  3. lines and symbols
    By luisjeronimo in forum AutoCAD Beginners' Area
    Last Post: 5th Sep 2007, 07:36 pm
  4. Import hand drawn symbols and make them autocad symbols
    By midwestpatsfan in forum AutoCAD General
    Last Post: 18th Dec 2006, 11:43 am
  5. How do I make my own blocks? or symbols?
    By rehabb in forum AutoCAD General
    Last Post: 24th Feb 2005, 07:15 pm
