sandiegophil Posted April 20, 2011 Share Posted April 20, 2011 Hello, I am looking for a way to import an xml surface and, in the definition, have no path listed (like with an xref). If I remove the path it replaces it. The purpose being if i move a set of files, the paths would not have to be updated. Any and all help is appreciated. Thanks, Phil Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 21, 2011 Share Posted April 21, 2011 Typically, when looking for linked files, AutoCAD looks first in the current folder, i.e. the one containing the drawing. If you move the linked files along with the drawing, they should appear normally. If you don't move them, you'd have to update the links anyway. Maybe I'm not understanding the issue properly. Quote Link to comment Share on other sites More sharing options...
