bbankston Posted April 20, 2011 Share Posted April 20, 2011 I've tried redrawing the shape (which is all I could think of at this point), and I still can't get a hatch in the negative space of this extrusion. HELP. file attached. ANSI31.dwg Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 I got it to work after redrawing again using mostly the polyline tool. AutoCAD can be kinda testy sometimes, can't it? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 I didn't have a problem with it, but it did show a gap at this location. I would use PEDIT and join with a fuzz option to connect everything. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 SLW210, Thanks for taking a look. When I first tried to hatch the original drawing (done by someone else) it freakin' locked up my computer. I wonder why it worked on your computer? PEDIT, huh? I need to learn more about those "type-in" commands. I take it, it means, Polyline Edit? Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 Well... not my computer, it locked up AutoCAD. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 Might be I have 2011 full. I get the message and it highlights the gaps, but it will hatch anyway. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 I'm 08 LT. That could be it, SLW210. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 Then again maybe I am just big, green, angry and scary and when I say Hatch it Hatches. Quote Link to comment Share on other sites More sharing options...
Glen1980 Posted April 20, 2011 Share Posted April 20, 2011 Hatched first time for me too. LT2010 shows gaps like SLW210's screen shot but I don't think we have fuzz command yet. Efficiency fans might also use PE to start pedit! Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 20, 2011 Share Posted April 20, 2011 Ok, here's a new twist to it all. I opened it in 2010, and it refused to hatch. Did a pedit, tried to hatch again and it squawked about there being a gap at the far left screw spline. So I "undid" all the way back to the start, used the same hatch pattern as the first time, picked a different spot and it hatched just fine. The gap that Hulk was talking about is being caused by that vertical line not being quite tangent to the arc that starts the gasket reglet. Radius on that arc is .0345, and the vertical line is only 0.0344 from it's center. I know, I know, a 1/10,000 of an inch ain't much, but the devil is in the details. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 Ya'll want to see the original file that I had? See attached. ANSI31.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 That one wouldn't work, but I fixed in 5 seconds with a Rectangle and REGION. Made a good boundary. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 20, 2011 Share Posted April 20, 2011 if you list that one, it says it's a spline. when I hit pedit, it asks me if i want to turn it into a polyline, I say yes, it does, and then it hatches. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 Jack_O'neill, 08 LT doesn't give me that option. SLW210, CAD got hung up on your suggestion. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 Jack_O'neill, 08 LT doesn't give me that option. SLW210, CAD got hung up on your suggestion. Try the BOUNDARY command and select Region. Sounds like you may be having some memory problems, mine hesitated the slightest bit and went on and made the region. P.S. I tried it again and now mine has hung up. You may just have to redraw it if you do not have the spline conversion. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 It is redrawn. It's fixed (see post #2). I thought you guys were trying to figure out why it wouldn't. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 20, 2011 Share Posted April 20, 2011 It is redrawn. It's fixed (see post #2). I thought you guys were trying to figure out why it wouldn't. I was just trying to solve this, just thought you may have more to do also. I have not given up yet either. Weird how now mine is locking up on it, I may download it again seems like the first time I do it works, but if I undo and try to do it I lock up. Next time, just give someone a shout that has full and see if they can PEDIT and convert all to polylines and join it. Quote Link to comment Share on other sites More sharing options...
bbankston Posted April 20, 2011 Author Share Posted April 20, 2011 I hear ya, SLW210. It'd be great just to do this quickly on my end. 'Preciate the input and the help. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted April 20, 2011 Share Posted April 20, 2011 I'm just one of those guys that has to untie the knot. If it's a tangled up extension cord, a jewelry chain or something like this, I just like to see if I can untangle it. Quote Link to comment Share on other sites More sharing options...
BOB FINLEY Posted April 23, 2011 Share Posted April 23, 2011 I tried it on acad 2002 and 2010 with the same drawing. It won't fillet the 2 locations that the red circles display. In acad2010, when you try to hatch in either "select internal point" or "select objects", a message comes up "lines are coplanar". How can you bring all the lines, no matter what layer they are in, onto the same plane. Please reply. Bob finley Quote Link to comment Share on other sites More sharing options...
