Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    Map 3D 2011
    Apr 2011
    13
    Default importing data from excel into AutoCAD 2011 Map 3D
    I have an excel file with several thousand lines of data and they all have UTM coordinates attached to them. I would like to have the data mapped out as points once imported. Is there a way to import this data into AutoCAD without going through ODBC? I have also imported the data into Access so retrieving the data from there is possible as well.
    Junior Member
    Map 3D 2011
    Apr 2011
    13
    Also, once I get the data into AutoCAD, I would like to merge it (if that is the correct AutoCAD term) with some shapefiles I have already imported into AutoCAD. Any advice will be of help. Thanks!
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    592
    Quote Originally Posted by jmsimpson View Post
    A number of ways may work. What data is in the files as far as attributes or fields that you want to carry over? Are you just wanting points at the x&Y locations or data attached to them. Save the excel file to txt or CSV format and use the mapimport command and select the ACSII Point file format.
    Murph
    Need a boat or camper for the weekend?
    Junior Member
    Map 3D 2011
    Apr 2011
    13
    Default Data from Excel to AutoCAD
    Quote Originally Posted by Murph_map View Post
    I would like to plot the excel points and associated data from the file to the points. It's more complicated for my case because I am unable to use an ODBC connection. I've tried importing the data as an ASCII file and it hasn't worked.
  5. #5
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    592
    Right ODBC doesn't work with Excel files in 2011, Access or SQL does. Can you post the first few records (rows) of the data you need to import? Also are you using Civil3D (this is the C3D forum)
    Murph
  6. #6
    Junior Member
    Map 3D 2011
    Apr 2011
    13
    Hi Murph,
    Here are a few lines of my data. As far as description goes, is there anyway to inject more than one criteria of description into the inputed data?
    Point UTMe UTMn Z Desc
    15-0288 4187600.24 251578.12 0 ABCO
    23-0807 4187755.37 251742.63 0 ABCO
    28-0055 4187470.64 251826.78 0 ABCO
    29-0015 4187463.77 251834.07 0 ABCO
    Thanks for your input!
  7. #7
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,106
    Is there a reason you have decided to create a second post?
    I merged and cleaned up the two threads. Next time just request to have it moved. It is less confusing for those that answer your question.
  8. #8
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    592
    Hi Murph,
    If you delete the first line (Point, UTMe, etc) and use PENZD Space Delimited your points insert OK. Check the coordinate system and then you may have to scale the blocks used for the point marker after the import.
    Murph
  9. #9
    Junior Member
    Map 3D 2011
    Apr 2011
    13
    Murph,
    That kind of worked. What I need to do now is make the points smaller. Why is each point represented by a large crosshair and how can I reduce the size of the font and the crosshair so my thousands of points are readable.
    Thanks for the help
  10. #10
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    592
    The crosshairs and text are the blocks that it uses to bring the points in. You can select them all (or use Quick Select and select all blocks named Map_survey_point) then in the property palette set the X,Y,Z scale to a smaller number.
    Murph
  1. Excel Data into AutoCAD 2011
    By Tekenmeester in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Sep 2010, 10:59 am
  2. importing excel data
    By isaac gitau in forum AutoCAD General
    Last Post: 7th Sep 2010, 03:48 am
  3. Excel Data Importing (not as a chart)
    By KadenStewart in forum AutoCAD General
    Last Post: 14th Apr 2010, 02:09 am
  4. Importing Excel File And Using Data Diractly
    By MAHESH KATORE in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Apr 2009, 06:11 am
  5. Importing data from an excel spread sheet
    By Ozymandias in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2008, 01:31 pm
Tags for this Thread
