Results 1 to 3 of 3
    Full Member
    AutoCAD 2006
    Sep 2010
    Houston, Tx
    47
    Default Command that numbers
    I used to do this but have forgotten the command.
    Picture an elevation of a glass building and I need to label and number each piece of glass. If each piece needs to start with "A" then a number I used to array the letter "A" then select them. This is when I would enter "the" command and it would let me pick the order I wanted it to number (order of selection, X, Y). If I selected x it would automatically add numbers across the X axis and I would end up with the glass labeled A1, A2, A3, ...... Perfect.
    Jog my memory please.
    Full Member
    AutoCAD 2006
    Sep 2010
    Houston, Tx
    47
    Never mind, I remembered.
    Tcount
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,664
    This lisp might be of interest also to you: http://lee-mac.com/numinc.html
  1. Convert integers numbers into real numbers, introducing decimal separator.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2010, 04:07 pm
  2. add numbers
    By hay123 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Apr 2010, 08:44 am
  3. Help with numbers
    By Nick-H- in forum AutoCAD General
    Last Post: 14th Oct 2009, 06:23 pm
  4. adding numbers to numbers
    By philk in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Feb 2006, 05:45 pm
