Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Forum Newbie
    AutoCAD LT 2011
    Apr 2011
    4
    Heres the drawing im trying to replicate
    And heres where im at with the drawing
    The blue line is the line the program tells me to draw indicating where i want the bend.
    JD what your saying is i need to draw the part as it will be formed and then flatten it to get my 2D image?
  2. #12
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Here are a couple of solutions.
    Notice the differences in the chamfered bend corners - AutoCAD users (particularly 2D) miss these subtle differences in sheet metal.
    I couldn't read your dimensions - so I just made some up.
    Edit Sketch1 to see that it is simply two lines, then use Countoured Flange to create the part.
  3. #13
    Forum Newbie
    AutoCAD LT 2011
    Apr 2011
    4
    Eureka!
    I think my problem was in extruding the part instead of using the face feature in the sheetmetal toolbar. I can bend the part now.
    One thing i did notice tho is i didnt see a way to indicate how thick i want the part in the face setting.
  4. #14
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    See the Sheet Metal Defaults icon - upper right corner of your screen - that sets the material thickness.
  5. #15
    Senior Member CADguy209's Avatar
    AutoCAD 2013
    May 2008
    Stockton, CA
    110
    Heres my results.....dimensions I just fudged since you cant see them in the pic.
  6. #16
    Junior Member
    Mechanical
    dascott's Discipline Details
    Go-To Guy @ RJ Corman RR Co
    Mechanical
    AutoCAD 2011
    Jun 2011
    Nicholasville, KY. USA
    14
    good morning. i have just read though this thread and i am struggling to do something similar with one key difference. we are currently building a (narrow) backhoe bucket. the bottom is made from a piece of 48 x 7 x 3/4" steel with an oval cut out of it for a hook to hang through. the piece then gets bent (we call it rolled, or broke) to create a curve to match the sides. my problem is that the cut-out oval is in the curve, and i cant figure out how to do this. i am very new to 2011, upgrading from 07LT, and this website has been crucial to me learning to do what i have. thanks in advance for any help.
  7. #17
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Attach what you have been able to complete so far. (dont worry about the oval cut for now.
  8. #18
    Junior Member
    Mechanical
    Mechanical
    AutoCAD 2011
    Jun 2011
    14
    here is what i have. at one point i had the plate (without the oval) bent to match the curve of the side (there in white), but deleted it to start over. after that is when i turned to CADTutor.
  9. #19
    Junior Member
    Mechanical
    Mechanical
    AutoCAD 2011
    Jun 2011
    14
    Is anyone able to help me on this?
  10. #20
    Junior Member
    Mechanical
    Mechanical
    AutoCAD 2011
    Jun 2011
    14
    ...thought i might give this one more try....
  1. "explode" (distance) parts - solids
    By sloman in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2013, 06:45 pm
  2. (command "dim" "DIMLDRBLK" "" |) is not working
    By bijoyvm in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2010, 12:15 pm
  3. (read (strcat "(" "1.5X250X600" ")"))
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jul 2010, 01:05 pm
  4. (read (strcat "(" "TUBE150X150X4.5 20.2" ")"))
    Last Post: 21st Jun 2010, 03:40 am
  5. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
