Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    Junior Member
    AutoCAD 2010
    Dec 2010
    Vegas
    10
    i was getting annoyed with the save message every time i opened or created a new drawing. the code in the original post was perfect and got it setup with the variables i use. next step is to get it on the rest of the computers so the message is gone everywhere.
  2. #22
    Full Member
    S-8-N's Computer Details
    Windows 7
    See details...
    S-8-N's Discipline Details
    CAD Drafter 1
    See details below.
    Audio / Video Wiring Diagrams and Equipment location details
    AutoCAD 2012
    Nov 2011
    Scappoose Oregon
    28
    This might not be part of this problem or a solution to the problem (I am still a rookie) but doesn't the EXPERT seting get rid of these simple questions? Just asking/saying might be the easiest way.
  3. #23
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,202
    Quote Originally Posted by S-8-N View Post
    Expert does not take care of "Save changes to drawingN.dwg".
    Controls whether certain prompts are issued.
    0 Issues all prompts normally.
    1 Suppresses "About to regen, proceed?" and "Really want to turn the current layer off?" (-LAYER)
    2 Suppresses the preceding prompts and "Block already defined. Redefine it?" (-BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK)
    3 Suppresses the preceding prompts and those issued by the LINETYPE Command prompt (-LINETYPE) if you try to load a linetype that's already loaded or create a new linetype in a file that already defines that linetype.
    4 Suppresses the preceding prompts and those issued by UCS Save and VPORTS Save if the name you supply already exists.
    5 Suppresses the prompt, "That name is already in Use, redefine it?" issued by the -DIMSTYLE Save option when you supply the name of an existing dimension style.
    Suppresses the same prompt issued by the -SCALELISTEDIT Add option.
    When a prompt is suppressed by EXPERT, the operation in question is performed as though you entered y at the prompt. Setting EXPERT can affect scripts, menu macros, AutoLISP, and the command functions.
  4. #24
    Forum Newbie
    AutoCAD 2009
    Jun 2012
    9
    Hi,
    i'm new to autocad programming. I'd like to use this code so I do not get prompted "do you want to save drawing" every time I open a file from an hyperlink in excel.
    Can anyone guide me on how and where do I throw this piece of code? I created acad.lsp and acaddoc.lsp with the code on post #1 but it doesn't work. (I verified that those two files are loaded at startup as well).
    Thanks!
  5. #25
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,639
    Quote Originally Posted by Chronik View Post
    Hi,
    Before doing so, do you know why you are being prompted to save a new drawing when you close it? You will only be prompted if a change is made to the drawing.
    If you take care to not make any drawing changes at startup time (with any of the various startup files), then you won't get prompted, and you won't need any "code".
  6. #26
    Forum Newbie
    AutoCAD 2009
    Jun 2012
    9
    Quote Originally Posted by rkmcswain View Post
    Hi, I am not doing any changes at startup, and i get promped "do you want to save dwg1" when clicking on an excel hyperlink while autocad was not running beforehand.
    Thanks!
  1. How to solve "Drawing Recovery" message
    By khoshravan in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 10th Dec 2010, 08:06 pm
  2. Replies: 0
    Last Post: 15th Nov 2010, 08:30 am
  3. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 17th Feb 2010, 06:45 am
  4. AcadMap3D 2010_freezes on "open" or "save" ...
    By Jest in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 26th Aug 2009, 08:27 am
  5. After command 'copy': "Autocad message: item added" WHY?
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2009, 12:24 pm
