Results 1 to 2 of 2
    Senior Member tennis4you's Avatar
    tennis4you's Computer Details
    Windows 7
    GIGABYTE GA-G41MT-S2P LGA 775
    2 Duo E5700 3.0GHZ
    4 Gigs
    evga g210 1gb ddr3 pcie lp dvh
    500 Gigs
    External
    (2) 23" Monitors
    AutoCAD LT 2012
    Apr 2011
    Ohio
    204
    Default Converting from MicroStation
    I have only ever used MicroStation at all 3 firms I have worked for. I am starting my own company and thinking about using AutoCAD instead.
    How do I deal with pen tables? I would like to be able to convert MicroStation files into AutoCAD and use line weights. It would be nice for AutoCAD to print those old MicroStation line weights well. Is that possible?
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    858
    If you still have the original DGN files and MicroStation you can define the DWG export parameters.
    When you open a DGN in AutoCAD a Wizard is started where you can map the MicroStation settings to AutoCAD settings (layers, line types, line weights, colour tables, etc) and these settings can be saved so that you have different conversion setting for different situations. We use MicroStation V8i together with AutoCAD 2004 to 2012 and experience no problems whatsoever opening DGNs in AutoCAD.
    You can open a DGN in AutoCAD and can also save a changed drawing as a DGN. A big difference between the two is that unlike MicroStation your work is not automatically and immediately saved, so after a crash in MS you never lose data . Honestly said MS is far more stable than AutoCAD.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  1. Microstation
    By CADbug in forum MicroStation
    Last Post: 7th Dec 2012, 11:02 am
  2. Converting from AutoCAD to Microstation
    By ryan in forum MicroStation
    Last Post: 12th May 2011, 07:03 am
  3. Converting from Microstation to autocad
    By neelsh in forum AutoCAD Drawing Management & Output
    Last Post: 20th Nov 2007, 06:02 pm
  4. converting to auto cad dwg. from microstation V8
    By studiorat in forum Autodesk Software General
    Last Post: 19th Nov 2007, 07:09 pm
  5. Converting a 3D solid from autocad to microstation
    By danny_macd in forum AutoCAD General
    Last Post: 18th May 2006, 04:44 pm
