Results 1 to 3 of 3
Thread: Defaut Template
    Senior Member tennis4you's Avatar
    tennis4you's Computer Details
    Windows 7
    GIGABYTE GA-G41MT-S2P LGA 775
    2 Duo E5700 3.0GHZ
    4 Gigs
    evga g210 1gb ddr3 pcie lp dvh
    500 Gigs
    External
    (2) 23" Monitors
    AutoCAD LT 2012
    Apr 2011
    Ohio
    204
    Default Defaut Template
    Is there a way to set the default template for new file creation? I made a template file but it keeps defaulting to another location for templates. As a matter of fact, I would love for it to not even ask me what template file I want to use, I just want it to use the one I made.
    Thanks!
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    type in options. Under the 'file' tab go down and double click on 'template settings', there are 4 options here, change the file location of the 3rd one 'QNEW' and that will make it your default. If you change the 1st option that changes the directory location for templates.
    Windows 7
    2 Duo E5700 3.0GHZ
    4 Gigs
    500 Gigs
    External
    (2) 23" Monitors
    AutoCAD LT 2012
    Apr 2011
    Ohio
    204
    That helped, thanks!
  1. A4 Template
    By matt4 in forum AutoCAD Beginners' Area
    Last Post: 8th Feb 2009, 01:41 am
  2. scaling up an A1 template to an A0 template
    By treeman in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2008, 04:34 pm
  3. Template
    By Starkey in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2007, 11:47 pm
  4. A4 Template
    By gw4100 in forum AutoCAD General
    Last Post: 26th Oct 2006, 10:17 am
  5. Drawing Template vs. Settings Template?
    By umop-3p!sdn in forum AutoCAD Beginners' Area
    Last Post: 20th May 2006, 01:09 am
