Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    Civil 3D 2011
    Nov 2009
    Somewhere between heaven and hell
    64
    Default Delete unused blocks
    Hi,
    I have an CAD file with a lot blocks which I don't use. I would like to delete them. So I do "Purge" which took care of some but not all. There are still a lot of "cannot purge" blocks. So I do "Insert", I see about 30 blocks. Choosing one of those, I can edit the block. (Doing the "Insert" was just my beginner's test step to see how many unwant blocks I still have.) I believe they cannot be purged because they are nested.
    How can I delete the 'cannot be purged" unused blocks?
    I know a lot of the blocks have other blocks nested in them. Is deleting the 'parent' blocks enough for me to purge?
    Thanks.
    PS: I only have limited knowledge with AutoCAD, so please be more specific of what to do.
    Senior Member
    AutoCAD 2015
    Sep 2010
    New Zealand
    217
    If you have a block or nested block in the drawing then you will not be able to purge them. You will need to get rid of every instance of that block before you can purge it out.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    Use _QSELECT and use the different options available to select the blocks and delete them. Purge is not a delete tool, it purges UNUSED block definitions, dimension styles, layers, linetypes, text styles, zero-length geometry and empty text objects.
    ALL references to a block must be erased before you can purge the block definition.
    P.S.
    Do any of the blocks have names that start with *?
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    867
    Quote Originally Posted by salmonrose View Post
    i do the same, but i use RENAME. this lists lots of objects in the drawing, which i find better than using the design center (Ctrl+2)
    as mentioned above, if you delete all the instances of a block, whether nested or not, you can purge their definitions and they will be gone forever.
  5. #5
    Junior Member
    AutoCAD 2014
    Oct 2014
    18
    I have the same problem. It's terrible because the file size is big
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Purge renaming etc will not work !!! Very simple with CIV3d run PURGESTYLES this will remove unused styles this in turn allows the purging of unused blocks that are linked to a style as well as layers linetypes etc. Styles lock their child components. To get a style back simplest way is IMPORTSTYLES. Did one today removed 330 styles then purged etc
  7. #7
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    637
    He may have blocks that were part of a xref those cannot be purged unless the xref is detached
  8. #8
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by Ski_Me View Post
    This information is not correct. Blocks from an XREF do not get inserted to the referencing file. XREFs do not increase file size by any noticeable amount.
    Drafting is a breeze.
  9. #9
    Forum Newbie
    AutoCAD LT 2015
    Dec 2014
    1
    Smile I am having the same issue on 2015 LT autocad!!
    So i have tried many things to get rid of older blocks that where somehow imported into our template. I can see them I hit Ctrl+2, some of the ones I want to get rid of have names like "A$C51A644A3"
    I have tried the filter option and the _qselect. Filter allows me to select those blocks but after searching each of my layouts and model space I did not see them. _qselect does not give me an option to select these type of blocks by name. They are not listed in the drop down menu and if I manually enter the name it highlights every object.
    Do you have any suggestions... i just want to delete every instance of the object... if it happens to delete something with it that would be fine just as long as the blocks are gone.
    Thank you if you respond I know it was years ago when you posted your comment.
    Quote Originally Posted by SLW210 View Post
    P.S.
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    It could be that you have instances of anonymous blocks in your drawing. Please attach a copy of the drawing file to your next post. Someone here will take a look at it. If the file is too large then you'll have to use a file sharing website like Dropbox.
  1. Delete blocks
    By mtunick62683 in forum AutoCAD General
    Last Post: 8th Jan 2014, 03:24 pm
  2. how to delete the blocks?
    By zainuddin in forum AutoCAD General
    Last Post: 12th May 2009, 12:48 pm
  3. delete unused window style
    By blatz.boy in forum AutoCAD General
    Last Post: 27th Oct 2008, 03:36 pm
  4. about deleting unwanted and unused blocks and layers
    By alijahed in forum AutoCAD General
    Last Post: 7th Jul 2008, 09:40 am
  5. Delete blocks in VBA
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2007, 05:16 pm
