Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 77
    Full Member
    AutoCAD 2011
    May 2011
    50
    Unhappy Scales, viewports, millimetres, m, plottinc confusion.
    Hi.
    I was up to 4am tryin to fathom this out and have deadlines looming.
    Despite having the manuals and other books I cant work out what settings I need.
    Simply put I want to draw some things that are about 1- 2m square and print on A1 at about 1:10. That feels like they should fit Ok.
    Now, what setting should I use? I worry I may have reset something my mistake.
    Can someone give m an idiots guide to how the page should be set up please?
    Drawing units are decimal- but should the block scaling box be m or mm [or does that not really matter unless I'm doing block scaling?]
    Do I draw in m or mm ? my drawing seem to be either too big or too small so when I open the view port and click 1:10 they are either HUGE or tiny. I know this isn't right and suspect it has something to do with Page Set Up Manager units in the model/paper space.
    Any pointers please? I'm doing a uni course and live 100 miles from campus and need to get this stuff printed by end of today.
    many thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Did you draw everything in model space at full size or did you scale objects much like you would if you did it on a drafting board?
    Did you use a metric template?
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    867
    i don't have time to explain it all, i'm sure someone else will, but maybe the attached file will help? it's A1, scale 1:10, with a 1 x 1.5m box drawn in.
    layout.dwg
    Full Member
    AutoCAD 2011
    May 2011
    50
    I drew full scale. but i tried both m [ie very small drawing] and mm [ie very big]. Thanks for the file Stuart, Im just going to look at that.
    I strated with acadiso sheet? is that right?
  5. #5
    Full Member
    AutoCAD 2011
    May 2011
    50
    Stuart. You are a lifesaver.
    Thanks so much. That's just what I need.
    Is it really complicated or am I just a slow-learner?!
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Model space: full scale. Good.
    Acadiso.dwt also good.
    After you scaled your viewport did you happen to also enable "display lock" so you wouldn't accidentally change the viewport scale?
  7. #7
    Super Member
    xp
    various
    Architectural
    architect
    Architectural
    ADT 2009
    Jun 2010
    867
    Quote Originally Posted by Miniver View Post
    no problem!
    in my experience there are lots of things to wrong at the beginning. i think it's better if you just start with one that works, and learn from there! of course, do not expect to have your work done for you here, this was a special case where it was best for both of us if i just gave you a file!
    ps i locked the viewport at scale 1:10 but you can unlock it to change the scale if necessary (use properties palette). lucky as remark was enforcing the "always lock your viewports" regime!
    Phew!
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    In my opinion AutoDesk does not make it easy to work in metric units.
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    In my opinion, AutoDesk makes it totally baffling to work in Imperial units
  10. #10
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Why do you think that? I find it perfectly fine.
  1. Line type scales in viewports
    By SREMO in forum AutoCAD Drawing Management & Output
    Last Post: 14th Sep 2009, 01:45 pm
  2. Viewports and Scales
    By wayne_04_uk in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2009, 04:43 pm
  3. Replies: 2
    Last Post: 28th Jan 2009, 11:12 pm
  4. viewports and scales need help asap!!!!!
    By kaya in forum AutoCAD General
    Last Post: 14th Feb 2006, 10:46 pm
  5. setting viewports scales from model to paper space
    By RDHOS in forum AutoCAD Beginners' Area
    Last Post: 7th Jan 2005, 08:41 pm
Tags for this Thread
