Results 1 to 4 of 4
    Senior Member
    Mechanical 2008
    Feb 2006
    England (Leeds)
    287
    Default How to import google sketchup file into inventor?
    I I have google sketchup pro and have been given an image to try to insert to inventor, so we can add conveyors and hoppers, various other blocks.
    I have managed to export the drawing into a Autocad 3D drawing, but from here I can't seem to find a way to get this in inventor.
    Can anyone help? I have attached the dwg file, if anyone can make this into a part/assy for inventor then I would be very grateful and intrigues how you did it!
    Many thanks,
    Stephen
    File is 1.4mb so I have uploaded it to this website:-
    http://www.filesonic.com/file/937491...onbridge3d.zip
    Ste G
    Director
    UK-CAD Solutions Ltd.
    UKCADS@googlemail.com
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    The problem you've got here is that Sketchup creates a mesh model and Inventor Creates a solid model. Even if you get the Mesh into Inventor it will appear 'Jagged' - Circles and arcs will look like polygons and faces will be composed of a number of triangles.
    Check Out this post for an explanation of the differences:
    http://cadsetterout.com/cad-setter-o...-a-3d-package/
    You could try exporting to SAT, which Inventor should read.
    You could try this download from Sycode:
    http://www.sycode.com/products/skp_import_iv/index.htm
    (Includes a good graphic that shows what you are going to get)
    You would probably be better off re-modelling the part in Inventor.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Inventor will import the dwg, but as indicated, faceted surfaces are of little use in Inventor other than for reference.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Senior Member
    Mechanical 2008
    Feb 2006
    England (Leeds)
    287
    Quote Originally Posted by JD Mather View Post
    I see, although when I try and import my Inventor just locks up, it's obvious something is not right. My method will have to be the other way around, export the inventor parts/blocks to 3ds and then add to sketchup, this will be suffice for this project!
    Thanks again guys.
    Ste G
    Director
  1. How to Import XML file from CODEWARE into Inventor 2011 Pro
    By fcfcadd in forum Autodesk Inventor
    Last Post: 1st Oct 2010, 04:50 pm
  2. Import .Sat 3D file to Inventor NOT working HELP :)
    By Abbyjay in forum Autodesk Inventor
    Last Post: 22nd Jul 2010, 07:06 pm
  3. AutoCAD to Google SketchUp
    By DanielMaid in forum SketchUp
    Last Post: 19th Sep 2007, 03:42 pm
  4. Import STEP file from Inventor
    By boot in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2007, 03:55 pm
  5. SketchUp and Google Earth
    By Lazer in forum SketchUp
    Last Post: 21st Apr 2006, 05:22 pm
