Change dimensions all at one time?
Mason Dixon
In the example below, I would like to select the three dimensions 14'-1 3/8's, 2', 28' and be able to move them all up or down at the same time...how do I do that?
Stretch doesn't seem to work the way I would like it to. I was hoping I could select the dimensions and move the grip of one of them and that would move all of the dimensions up or down at the same time.
That's the way _STRETCH works on my AutoCAD.
** STRETCH **
Specify stretch point or [base point/Copy/Undo/eXit]: _cen of
Command: *Cancel*
Command:
Command:
Command: _stretch
Select objects to stretch by crossing-window or crossing-polygon...
Select objects: Specify opposite corner: 4 found
Select objects:
Specify base point or [Displacement] :
Specify second point or : *Cancel*
What does that even mean?
I use stretch for this very task (on occasion), and it allows me to take multiple, in-line dimensions.
