raymarcher Posted May 13, 2011 Share Posted May 13, 2011 Me again, How can I drag-select muliple vertex points form a polyline, a workaround I found is: -select object -shift select first vertex, shift select next vertex, etc But this workaround is limited because I want to delete those vertexes, I cannot find the remove vertex command when I have multiple vertexes selected. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 13, 2011 Share Posted May 13, 2011 I believe you will have to use the old method: PEDIT>EDIT>STRAIGHTEN>NEXT>NEXT>NEXT>GO Quote Link to comment Share on other sites More sharing options...
raymarcher Posted May 13, 2011 Author Share Posted May 13, 2011 Why is that so limited? In illustrator you can select all the vertexes and modify them. Quote Link to comment Share on other sites More sharing options...
