+ Reply to Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
  1. #21
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,134
    Default
    Just so we are clear. Your geometry is in model space. Where is your text and dimensions? Are they in model space too? And how about your title block and border, where are they? Model space or paper space? If they are in paper space have you created a viewport?
  2. #22
    Junior Member
    Computer Details
    dgolchuk's Computer Details
    Operating System:
    windows 7
    Monitor:
    48" LG LCD
    Discipline
    Construction
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    Ontario, Canada
    Posts
    11
    Default plot scale
    Everything is in model space. I have not yet made a viewport. i have checked through my books to make sure i wasnt having a "moment". This is the first time they have stated "use a PLOTTING scale 1" = 1' and a LTSCALE of 12.
  3. #23
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,134
    Default
    Where did the reference to paper space come in? It sounds to me like you'll be plotting from model space not paper space. Plots done in paper space are usually at 1:1 scale since the viewports are scaled separately.
  4. #24
    Junior Member
    Computer Details
    Operating System:
    windows 7
    Monitor:
    48" LG LCD
    Discipline
    Construction
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    Ontario, Canada
    Posts
    11
    Default
    You are correct, they didnt mention anything about paper space (never really do in this course). So that being said i guess it will remain in model space which still leaves me lost lol
  5. #25
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,134
    Default
    When you go to the PLOT dialog box you will select the scale of 1"=1'.
    I'm going for a motorcycle ride. Upon my return I'll check this thread. Good luck.
  6. #26
    Junior Member
    Computer Details
    Operating System:
    windows 7
    Monitor:
    48" LG LCD
    Discipline
    Construction
    Using
    AutoCAD 2012
    Join Date
    Mar 2012
    Location
    Ontario, Canada
    Posts
    11
    Default
    Cool. currently in a boring meeting but i will give it a shot after. thanks bud!
  7. #27
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    Aug 2012
    Posts
    1
    Default Auto cad basics
    hi car..am a beginner to CAD...i just have problem in joining lines...how to combine many lines into single line? i used "PEDIT" command and also JOIN command....but i cant combine it. for ex combine the trapezium with rectangle, both of same size as base. i have attached a picture..how to combine it as single thing!!! pls help me
  8. #28
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,134
    Default
    This particular thread is about a Penn-Foster student project.
    PEDIT and JOIN usually work unless you have lines at different "Z" elevations or large gaps where your ends "appear" to meet.
  9. #29
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,134
    Default
    Let's assume all lines are at elevation "0".
    One option is to run the PEDIT command, type "M" (for Multiple), select all the lines then type "J" for JOIN. When prompted for a "fuzz distance" put in a large number (ex. - like "1") and see what happens.
    It would go something like this.....
    Command: PE
    PEDIT Select polyline or [Multiple]: M
    Select objects: Specify opposite corner: 4 found
    Select objects:
    Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype
    gen/Reverse/Undo]: J
    Join Type = Extend
    Enter fuzz distance or [Jointype] <0.1250>: 1.0
    3 segments added to polyline
  10. #30
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2012
    Posts
    33
    Default
    this plate at the end, (plate2) asks to figure out the area of the transition patterns youve created. how do you figure out the area? each separate piece or is there a special formula to do it?
Similar Threads
  1. Civil drafting school project help
    By Autocadstudent in forum Student Project Questions
    Last Post: 24th Apr 2013, 04:23 pm
  2. school CAD project
    By bdr2k5 in forum Student Project Questions
    Last Post: 25th Apr 2010, 11:44 am
  3. I need an interviewee for a school project.
    By AlwaysLola in forum AutoCAD Beginners' Area
    Last Post: 9th May 2007, 02:33 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
