Page 5 of 11 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 103
  1. #41
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Yes, I agree, we learn best by doing. Practice, practice and practice some more. It just makes us better.
  2. #42
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    Hey remark I see in the instruction it said to put the building dimention . is that includes the inside partition walls and all other the given dimention in the insid too in plate A or we just put the dimention for overall dimention around it only.
  3. #43
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    dimension question
  4. #44
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    is ther any key to press in the autocad to masure all the dimension one time by high light the area
  5. #45
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    No there is not.
    If you wanted to know the lengths of all the lines in your drawing you would either have to use the LIST command and select all the lines or use a custom lisp routine.
    Why do you ask?
    Wait a minute...
    Are you asking if you can dimension an entire drawing with a press of a single key? If so the answer would still be "no" but there is a Quick Dimension feature in AutoCAD that might help. Be careful when using it though as the results can be unpredictable at times depending on how you pick the objects you want to dimension.
  6. #46
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    The reason i asked is ,I useed the softwar called home designers and u build some kind of frame work with out any measurment, after u finished placing the frame work and all partition wall then just u hit the auto dimension button and that will put all the measurment in place .
    so that why i asked if we can do the same thing/ OR AUTOCAD HAS SOME KIND OF WAY DOING THIS once we build the frame work .
    Thanks
  7. #47
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    There is no feature like that in AutoCAD.
  8. #48
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    ok thanks i was just curious about the application. so which one is the fastest way to put the dimension fast except by turning the osnap and go from there by picking the qwick dimension command .
  9. #49
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    The fastest way would be to use the Quick Dimension feature. Just be careful where and how you pick on your geometry. The use of OSnaps when making picks is highly recommended when it comes to accuracy.
  10. #50
    Full Member
    AutoCAD 2010
    Dec 2012
    79
    hello all ,Remark.
    please is any one has the HVAC plate#2 labeling on the numbers , i did the drawing but got confusing how to label them . i see some pdf picture put it is very hard to see how the numbers labeled please help in this one
  1. Civil drafting school project help
    By Autocadstudent in forum Student Project Questions
    Last Post: 22nd Mar 2018, 02:55 pm
  2. school CAD project
    By bdr2k5 in forum Student Project Questions
    Last Post: 25th Apr 2010, 11:44 am
  3. I need an interviewee for a school project.
    By AlwaysLola in forum AutoCAD Beginners' Area
    Last Post: 9th May 2007, 02:33 pm
