lisp to move objects over 20in
MikeP
Im being totally lazy on this one. but what would a lisp look like to simply select an object enter the command and all it does it move the object over 20" to left?
Simplest way:
(defun c:test ( / ss )
 (if (setq ss (ssget "_:L"))
   (command "_.move" ss "" "_non" '(0. 0. 0.) "_non" '(-20 0. 0.))
:lol:
(defun c:LazyMove ( / ss pt)
 (princ "\rI'M TOALLY LAZY ")
 (if (and (setq ss (ssget))
          (setq pt (getpoint "\nSelect base point: ")))
   (command "._move" ss "" pt (cons (- (car pt) 20.) (cdr pt)))
   (cond (ss (prompt "\n** Invalid point ** "))
         ((prompt "** Nothing selected ** "))))
 (princ))
sorry dude, I like lees way... I dont wanna have to pick a base point.
No worries; I like his better too. LoL
to help me out. I dont understand the "_:L" or the "_non" parts of the lisp.
The "_:L" simply ignores locked layers during the selection. The "_non" simply removes any accidental OSNAP interference.
Sure :)
"_:L" - excludes objects on Locked Layers from the SelectionSet
"_non" - 'None' OSnap, i.e. ignore ObjectSnap for the next supplied point.
***Really?***
i have a number of objects that I have to keep moving over 20". In my head I justify laziness into efficiency.
  • Funny 1
Sure :)
thanks, but whats is the need to ignore those type of things? if you not asking for a base point. or is it just a safety to avoid any possible future errors?
Its definitely justified if the time taken to write the code is less than the time saved :)
I'm not prompting for a base point, but I'm still supplying the Move command with two points which may be affected by any objects surrounding those points.
My effort an oldie chx chy chz this is stuff 15 years old
(defun C:CHX ()
 (SETVAR "CMDECHO" 0)
 (setq sn (getvar "osmode"))
 (command "osnap" "near")
 (setq x 0)
 (princ "\nalters object in X direction")
 (setq ht (getstring "\n What is amount of change: "))
 (setq newht (strcat ht ",0"))
 (while (= x 0)
   (setq newobj (entsel "\nPoint to object: "))
   (if (/= newobj nil)
   (command "move" newobj "" "0,0" newht)
 (if (= newobj nil)(setq x 1))
(defun C:CHY ()
 (setq x 0)
 (princ "alters object in Y direction")
 (setq newht (strcat  "0," ht))
 (while (= x 0)
 (SETQ NEWobj (entsel "\nPoint to object: "))
 (if (/= newobj nil)
;simple routine to change objects in the z direction
(defun C:CHZ ()
 (setq x 0)
 (princ "alters object in Z direction")
 (setq newht (strcat "0,0," ht))
 (while (= x 0)
 (if (/= newobj nil)
 (command "move" newobj "" "0,0,0" newht)
Quick Select and Move wouldn't work?
How many times do you have to move the same objects 20"? What type of drawing is this?
Fyi,
In 2012 we can nudge object(s) using arrow. The distance can be determined using grid snap.
  • 1 year later...
Hello
This is very usefull in my field as we design Shopping malls and use Architects drawings to quickly draw over their lines for what is needed in another location in model space then draw our own design over the traced lines.
Is there a way to incorporate the pline command in Lee's lisp routine so the command first starts with Pline then automatically moves the object 20 in in left direction? Again we are not lazy cad users. it only removes the extra commands for each shape you draw (especially when you are tracing over a mall floor tiles)
Best Regards
Adsk2007
