Results 1 to 6 of 6
Thread: Trace
    Full Member
    AutoCAD 2011
    Aug 2010
    29
    Default Trace
    I have installed Autocad 2012 on my computer and it seems that they have removed the trace command. Does anyone have a lisp file that will allow me to continue using this command?
    Senior Member Ohnoto's Avatar
    AutoCAD 2012
    Jul 2010
    Somewhere Between ACAD and LISP
    154
    Look here.
    Full Member
    AutoCAD 2011
    Aug 2010
    29
    Perfect. Cheers mate.
    Full Member
    AutoCAD 2011
    Aug 2010
    29
    It worked. But when i close down cad and open it again i have to redefine it every time. How do i redefine it permanently??
  5. #5
    AutoCAD 2012
    Jul 2010
    154
    Two things you could do...
    1. Create a macro button:
    Code:
    ^C^C_redefine trace;
    2. Use the LISP attached below and put it in your startup suite. Command: AP
    Using the macro, you would need to hit once while in a drawing, where as the LISP would run and redefine it with each new drawing automatically.
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Simply type .trace at the command line, note the period in front of trace.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Is there?...trace the changes
    By Connect Project Tech in forum AutoCAD General
    Last Post: 27th Jan 2010, 01:26 pm
  2. Trace line .net
    By PanHasan in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Sep 2009, 11:25 pm
  3. How Do I Trace An Image?
    By Meglesniak323 in forum AutoCAD General
    Last Post: 10th May 2009, 07:28 pm
  4. Trace Tool?
    By jopton in forum AutoCAD Beginners' Area
    Last Post: 10th Oct 2007, 10:07 pm
  5. How to trace a Drawing?
    By Leech in forum AutoCAD Beginners' Area
    Last Post: 25th Oct 2006, 11:41 pm
