FieldGuyonCAD Posted May 20, 2011 Share Posted May 20, 2011 My computer crashed and IT just installed new Autocad 2011. When I enter the ribbon command I get the message "The Ribbon does not have any tabs or panels currently loaded." I know this must be an easy fix but please help me so I do not have to call IT back!! Thank you very much Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 20, 2011 Share Posted May 20, 2011 Make sure the main menu is loaded (Acad.cuix). Type in MENUNAME at the command line to check the current menu name. Type in MENU to load a menu file. Quote Link to comment Share on other sites More sharing options...
FieldGuyonCAD Posted May 20, 2011 Author Share Posted May 20, 2011 When I type in menu the only 4 I can load are ac11base acad11tb cs11base cs11base.bk any ideas? Quote Link to comment Share on other sites More sharing options...
rkent Posted May 20, 2011 Share Posted May 20, 2011 Try starting ACAD with a new profile. Modify a shortcut with "/p new" (no quotes) at the end of the target line. Quote Link to comment Share on other sites More sharing options...
FieldGuyonCAD Posted May 20, 2011 Author Share Posted May 20, 2011 I am not sure where to input the /p new command Also I have a attached a screen shot of the image too...please let me know Quote Link to comment Share on other sites More sharing options...
FieldGuyonCAD Posted May 20, 2011 Author Share Posted May 20, 2011 Got it!!! Thanks to rkmc Quote Link to comment Share on other sites More sharing options...
rkent Posted May 20, 2011 Share Posted May 20, 2011 Would you post what worked for you so others searching will know exactly how you fixed it? Thanks Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 20, 2011 Share Posted May 20, 2011 Try starting ACAD with a new profile. Modify a shortcut with "/p new" (no quotes) at the end of the target line. I am not sure where to input the /p new command FYI - In order to load a specific profile from the Application Icon, simple add the /P switch to the Icon's Target Property: "C:\Program Files\[color=red]<InstallFolder>[/color]\acad.exe" /p "[color=red]MyCustomProfile[/color]" More information on AutoCAD Startup Switches. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 20, 2011 Share Posted May 20, 2011 I am not sure where to input the /p new command Also I have a attached a screen shot of the image too...please let me know You are running Carlson Software, which hijacks the AutoCAD menu system replacing the defaults with Carlson's - and on top of that, they do not define any Ribbon tabs or panels in their menus. So what you are seeing is normal in the Carlson world. You should be able to change profiles to get back to the normal AutoCAD menus, but your Carlson stuff may not work unless you are in their profile. Quote Link to comment Share on other sites More sharing options...
Geoffers Posted May 24, 2011 Share Posted May 24, 2011 My computer crashed and IT just installed new Autocad 2011. When I enter the ribbon command I get the message "The Ribbon does not have any tabs or panels currently loaded." I know this must be an easy fix but please help me so I do not have to call IT back!! Thank you very much Verrry interresting - but can't help : this message appeared when I tried to open Architecture 09 about the same date. However my pc had not crashed and I don't run Carlson sw. I tried 'repair' but eventually had to 'reinstall' so losing my (few) customisations.:x Quote Link to comment Share on other sites More sharing options...
