LEIGH Posted May 22, 2011 Share Posted May 22, 2011 Hi all. I have recieved a CAD file which has just over 1000 circles. I need to convert all the circles to points. Autolisp is over my head - can anyone help? Thanks Quote Link to comment Share on other sites More sharing options...
eldon Posted May 22, 2011 Share Posted May 22, 2011 Set your Osnap to Centre. Start the command "point" and click away. You will be done in about twenty minutes. Unless some kind soul writes a lisp routine for you, but then you would have waited longer than twenty minutes. Quote Link to comment Share on other sites More sharing options...
LEIGH Posted May 22, 2011 Author Share Posted May 22, 2011 I've been looking all day at this. It seems I need a lisp to: select all circles, then either replace the circle with a point, or insert a point into the circle. Either or, it doesn't matter which. Can anyone help. I found: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Extract-Point-Data-CALLING-ALL-LISP-GURUS/m-p/885377 which would be fine in a way, but it converts circles to blocks, not points. A little stuck now? Quote Link to comment Share on other sites More sharing options...
LEIGH Posted May 22, 2011 Author Share Posted May 22, 2011 Set your Osnap to Centre. Start the command "point" and click away. You will be done in about twenty minutes. Unless some kind soul writes a lisp routine for you, but then you would have waited longer than twenty minutes. Thanks for your reply. Thing is, I will be getting more drawings - which would be around 6000 circles, plus what ever drawings this year I have to work with. Quote Link to comment Share on other sites More sharing options...
eldon Posted May 22, 2011 Share Posted May 22, 2011 If you have found something that converts circles to blocks, then you could edit the block to make it a Point. I am afraid that my first reply might have seemed a trifle flippant, but perhaps you should have been posting in the Lisp section of the forum. Quote Link to comment Share on other sites More sharing options...
LEIGH Posted May 22, 2011 Author Share Posted May 22, 2011 If you have found something that converts circles to blocks, then you could edit the block to make it a Point. I am afraid that my first reply might have seemed a trifle flippant, but perhaps you should have been posting in the Lisp section of the forum. Ah, i didnt know there was a lisp section. I'll have a look now. Thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 22, 2011 Share Posted May 22, 2011 For anyone else reading this thread, with a similar issue, the solution was found in post #19 here: http://www.cadtutor.net/forum/showthread.php?46891-Insert-a-point-at-each-vertex-of-selected-polys/page2 Quote Link to comment Share on other sites More sharing options...
Rainbowinthesky Posted January 22, 2016 Share Posted January 22, 2016 Search the Internet for a program C2P - It converts all Circles in the drawing to Points Instantly - I use this program frequently. Quote Link to comment Share on other sites More sharing options...
Rainbowinthesky Posted January 22, 2016 Share Posted January 22, 2016 Search the Internet for a program C2P - It converts all Circles in the drawing to Points Instantly - I use this program frequently. Vikas Kulkarni Pune India. Quote Link to comment Share on other sites More sharing options...
Mwolthuis Posted September 23, 2020 Share Posted September 23, 2020 You can explode the circles until you have two half-circles. Those have two points, left and right. Export those points to csv and open with excel. After that use formula to calculate the avarage coordinate from each first two set of X and Y (as seen in image). Remove the spaces in between and make a new point file. Import that file in CAD and check if it is the center, and you're done. P.s. this will mess up your work if there are individual single points in the export that are not part of the half circle Image: https://ibb.co/kctR1xs Quote Link to comment Share on other sites More sharing options...
ronjonp Posted September 23, 2020 Share Posted September 23, 2020 11 hours ago, Mwolthuis said: You can explode the circles until you have two half-circles. Those have two points, left and right. Export those points to csv and open with excel. After that use formula to calculate the avarage coordinate from each first two set of X and Y (as seen in image). Remove the spaces in between and make a new point file. Import that file in CAD and check if it is the center, and you're done. P.s. this will mess up your work if there are individual single points in the export that are not part of the half circle Image:https://ibb.co/kctR1xs Do you realize that the last post on this thread was 4 years ago? AFAIK you cannot explode circles. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 24, 2020 Share Posted September 24, 2020 (edited) Its like 4 lines of code to do it, very old post. Edited September 24, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
